ElPolloDiablo Posted January 15, 2022 Posted January 15, 2022 Hi all, So I own a '99 VFR800 which came with a high mount Nikko exhaust. Recently I picked up a set of Givi E360 panniers that came with the rack. I can't install the right rack because the Nikko exhaust is in the way. What are my options besides getting a stock exhaust just for the big trips or getting a low mount sports exhaust? I like high mounts better. So, are there are high mount exhaust for the VFR800 '99 that fit with the panniers? Thanks! Quote
Member Contributer Dutchy Posted January 15, 2022 Member Contributer Posted January 15, 2022 Cut and weld the righthand side of the rack so it sticks out a bit more? 1 1 Quote
Member Contributer bmart Posted January 15, 2022 Member Contributer Posted January 15, 2022 Does Nikko offer a low mount can/slip-on that will bolt to the header/midpipe directly? That's a few minute swap, and you get the sound you like for trips or forever. Quote
Member Contributer JZH Posted January 16, 2022 Member Contributer Posted January 16, 2022 Many high mounts are tucked in pretty close already, so spacing one of the racks out a little bit more to clear it is hardly noticeable. Alternatively, getting a spare low-mount pipe for touring, as mentioned, is an easy option. Ciao, JZH Quote
Member Contributer bmart Posted January 16, 2022 Member Contributer Posted January 16, 2022 <---all about easy. It is my business! Quote
