dozyproductions Posted October 31, 2019 Posted October 31, 2019 Really quick question. A lot of the f4i fork swap threads mention buying something similar to a f4i rear cylinder along with a f4i front M/C. Could some one explain to me exactly why? I have a suspension shop doing this job for me and the mechanic didn't want to keep the rear f4i cylinder because I couldn't give him a good enough reason to why. Any help? Thank you. Quote
Member Contributer Captain 80s Posted October 31, 2019 Member Contributer Posted October 31, 2019 I think it has to do with the diameter of the original not working great after de-link. 1 Quote
Member Contributer TheLimey Posted November 1, 2019 Member Contributer Posted November 1, 2019 You'll be operating all three of the rear caliper pistons with the rear master cylinder rather than just the outer two. The middle was previously operated by the secondary master cylinder on the front left caliper, but now you're going to link all three rear pistons together. 1 Quote
mello dude Posted November 1, 2019 Posted November 1, 2019 For a delink job and going to different front forks, .. for the rear you do need to change out the master cylinder to a 14mm diameter. Options.. F4i, VTR1000, RC51, CBR600RR. All use the same base castings. - I just bought a '02 RC51 m/c new, I didnt want to have to rebuild. --- The rear caliper pistons need to be working together. I used a bridge line that works fine, and one OEM brake line from the m/c to the caliper, I think I still have pictures in my gallery. - Other guys have just used 2 OEM lines to the caliper and then even others have just drilled out a path in the caliper so just one line is needed, and then one hydraulic port is sealed. All work fine. Please dont forget this step, your rear brake will be crap if you dont. Photos -- I have been running this setup a long time now, and it still works well. Cheers 2 Quote
dozyproductions Posted November 1, 2019 Author Posted November 1, 2019 Thank you guys! This was the last link 'we' needed! Gathering the parts, itself, has been a challenge being that so many of the used 'good' looking parts have had their own individual problems. The rear cylinder, that was already bought, doesn't seem to be an exception. Quote
Browny Posted August 28, 2023 Posted August 28, 2023 You can also use a CBR1000RR 06 - 22 rear master cylinder 43510-MEL-D22, 14mm bore, and extend the rod with an M8 x 1.25mm pitch coupling (hardware store) Quote
