TX _VFR Posted March 14, 2016 Share Posted March 14, 2016 Did a search and could not find it. I just ordered a set of Helibars and after reading the install threads about how much a PITA it is to get out the bar end weight dampers from the stock bars, I figure I'll just order brand new ones and avoid the cursing and throwing of tools. Does anybody have the part numbers for them and a place to buy them from for a good price ? TIA Link to comment Share on other sites More sharing options...
Member Contributer MadScientist Posted March 14, 2016 Member Contributer Share Posted March 14, 2016 Parts needed: 2 of each: 53105-KV3-000 - Weight B, Handlebar 53106-KT7-000 - Rubber A 53107-MB6-630 - Rubber B 53108-MAT-000 - Ring Do make sure that the internal diameter of the helibars is the same as the OEM bars otherwise you may have to trim the rubber pieces down. I usually drill a hole through the bars using a doweling jig so the tabs on the retaining clip (aka Ring) have something to lock into. Also, liberally spray the rubber parts with aerosol hairspray so they slide more easily into the bar and have some grip when the hairspray dries. Link to comment Share on other sites More sharing options...
Member Contributer Cogswell Posted March 14, 2016 Member Contributer Share Posted March 14, 2016 When I installed Heli's on my 6th gen, I threaded a sacrificial bolt in to the weight to clamp a vice grip on, then once the tabs were released both slid out as I had plenty of purchase on them. I did that with each bar still in place so I had something to pull against. I may have sprayed some WD40 or silicone lube in, but I don't recall now. Link to comment Share on other sites More sharing options...
Member Contributer MadScientist Posted March 14, 2016 Member Contributer Share Posted March 14, 2016 Yeah, I've removed with WD40 and a slide hammer Link to comment Share on other sites More sharing options...
TX _VFR Posted March 15, 2016 Author Share Posted March 15, 2016 Thanks for the tips, I appreciate it. Helibars came in yesterday, now I am going to order some new weights. Link to comment Share on other sites More sharing options...
V4Mitch Posted March 15, 2016 Share Posted March 15, 2016 I didn't check to verify in this case but most of the time I can find part numbers using motosport.com. Their part finder is really easy to use. They're overpriced so I never buy anything from them but a good reference none the less. Link to comment Share on other sites More sharing options...
Baileyrock Posted March 15, 2016 Share Posted March 15, 2016 I think the 98-99 weights were different then 00-01, be sure to check. Link to comment Share on other sites More sharing options...
TX _VFR Posted March 16, 2016 Author Share Posted March 16, 2016 I think the 98-99 weights were different then 00-01, be sure to check. Thanks for the tip, there was a different part # for one of the weights listed for 00-01 vs 98-99. Ordered the new weights this morning, hopefully will be here in the next week. Link to comment Share on other sites More sharing options...
ca315 Posted March 17, 2016 Share Posted March 17, 2016 Buy a set of these. You think the VFR is smooth until you put these on, then you realise you can feel the vibration in the pegs but not your hands. Probably cost less than the Honda parts. http://www.vibranator.com/ Link to comment Share on other sites More sharing options...
TX _VFR Posted March 21, 2016 Author Share Posted March 21, 2016 Buy a set of these. You think the VFR is smooth until you put these on, then you realise you can feel the vibration in the pegs but not your hands. Probably cost less than the Honda parts. http://www.vibranator.com/ Maybe Down Under they do, but here in the US they are about $132 AUD MORE than the Honda parts. ? Link to comment Share on other sites More sharing options...
ca315 Posted March 22, 2016 Share Posted March 22, 2016 "$132 AUD MORE than the Honda parts" ???? They are US$119 a pair!!! Link to comment Share on other sites More sharing options...
TX _VFR Posted March 22, 2016 Author Share Posted March 22, 2016 "$132 AUD MORE than the Honda parts" ???? They are US$119 a pair!!!YupThe Honda parts cost me US $38 Link to comment Share on other sites More sharing options...
