Pair Valve Cover
maxredline
Decided to DYI my valve clearance/throttle body sync/disable flapper and remove the pair valve plumbing. I bought a small torque wrench, angled feeler gauages and a set of decent vacuum gauges. After all is said and done the DYI will be less costly and I'll have some new tools..win, win.
I thought about just capping off the pair connections and have even heard of some that plug the connecting rubber tubes with marbles to block the air flow. I thought I might as well do a search to see if I could pick up a pair cover kit and ya, ebay, loving it.
http://www.ebay.com/itm/PAIR-Valve-Eliminator-SMOG-block-off-plates-Honda-CBR-VFR-800-600-1100-1000-PCV-/252055880649?hash=item3aafb383c9:g:6UMAAOSwbdpWXr~b&vxp=mtr
The Bike has 60K on it, ill let you know how many valves are out of spec when I get around to checking.
http://www.vfrdiscussion.com/forum/index.php/topic/78878-pair-valve-plates-for-5th-6th-gens/
http://www.vfrdiscussion.com/forum/index.php/topic/78499-new-pair-block-off-plates-mello-dudes-garage/
Check out above...mine are designed to fit EXACTLY to the VFR. The ebay design is more generic to fit a wider range of bikes, but wont do the exact fit thing.
