Years ago, I bought a DynoJet PCII off the Internet for my '01.
I had bought a Wolf underseat exhaust and wanted to improve the fueling curve. When I installed it, however, I had problems with the engine cutting out.
Too often it would occur are the worst times, like midway through a curve. I bought the O2 eliminators, but that didn't change anything. Then I discovered that the PC was meant for the '98-'99 model with the 'choke'. Dynojet was kind enough to reflash the unit for '00-'01 bikes, but that didn't improve anything and I finally took it off.
Fast forward to today.
I'm on my 2nd '01 and recently bought a Staintune highmount from a fellow VFRD member who included a PCII with a map for the Staintune (Thanks Maxswell!!). The map helped smooth out the acceleration and minimized the snatchiness when initially opening the throttle, so I was quite pleased with it.
I don't ride the bike daily as I used to, so it's rare that I'm in heavy traffic for any length of time. This past week, however, circumstances forced me to take the bike to work.
As I was riding home in normal Honolulu traffic (20-25 MPH for about 20 miles), the bike started cutting out, just like the other bike did so many years ago.
This time, however, it was much more frequent.
I'd say about 2-3 times in the span of 2 minutes, but not at regular intervals. I couldn't discern any sort of pattern to the problem.
Due to traffic, the bike was hot, but not obscenely so.
The temp gauge would hit 220, the fan would kick in and it would drop down to 210. I experienced the cut out in 1st, 2nd, and 3rd gears. I experienced it under acceleration, under deceleration and under heavy acceleration. This time around it was not on a curve; strictly straight line.
As I got closer to home and traffic thinned out, the pace picked up, the bike cooled down and the problem went away.
Although it would seem to be a heat-related issue, the fact that the PCII is mounted back by the ECU would lead me to believe that it's not a matter of the PCII itself overheating.
Another data point: The red FI indicator doesn't light up with the PCII installed, so I've not bothered with the O2 sensor eliminators.
Has anyone else had this problem? Is it possible that there's a mapping issue? That doesn't seem like a logical cause, but I'm not well versed in how the PC modifies the ECU signal.
Dynojet lists the PCIII USB as an applicable model for the 5th gen. Is it, or any other product, worth consideration to deal with this issue?
Question
ggathagan
6 answers to this question
