Lint Posted November 2, 2015 Share Posted November 2, 2015 So, I installed manual cam chain tensioners on my 05 and it's running fine, but what I haven't found is how much freepaly or slack there should be on the cam chains, so I know that my tensioners are not too tight not too loose. GGoing by ear is one thing, but knowing it is within spec is another. I looked in the downloadable service manual, but I haven't found it yet. This will also let me know that the cam chains are within spec also.Please let me know. Link to comment Share on other sites More sharing options...
Tarrant Posted November 6, 2015 Share Posted November 6, 2015 I'm running APE's on mine currently. Use the screwdriver against the engine method, If you can hear a rattle, nip it up a tad. if it sounds like a 5th gen, back it off. Link to comment Share on other sites More sharing options...
keef Posted November 6, 2015 Share Posted November 6, 2015 What is this cam...chain... you speak of? Link to comment Share on other sites More sharing options...
Lint Posted November 6, 2015 Author Share Posted November 6, 2015 What is this cam...chain... you speak of? Haha! I wish they never got rid of the gear drive! Link to comment Share on other sites More sharing options...
superfunkomatic Posted November 6, 2015 Share Posted November 6, 2015 As far as I know, if you've replaced them, they are spring-loaded and put pressure on the cam chain automatically. They aren't adjustable that I'm aware of. The spring does all the work and when it wears out then it's time for a replacement. I know some on the forum have added manual ones that can be adjusted. I'm sure someone will chime in and talk about alternatives. Link to comment Share on other sites More sharing options...
Lint Posted November 6, 2015 Author Share Posted November 6, 2015 As far as I know, if you've replaced them, they are spring-loaded and put pressure on the cam chain automatically. They aren't adjustable that I'm aware of. The spring does all the work and when it wears out then it's time for a replacement. I know some on the forum have added manual ones that can be adjusted. I'm sure someone will chime in and talk about alternatives. I installed manual cam chain tensioners. I simply followed the install guide for APE tensioners; To set the tensioner adjustment, rotate the engine forward while screwing the tensioner bolt in. When you feel the engine tensioner parts (guide, rollers, etc.) make contact with the moving cam chain, back the tensioner bolt out 1/4 turn and tighten the jam nut. Link to comment Share on other sites More sharing options...
