fuelex Posted September 10, 2015 Share Posted September 10, 2015 This morning my eight day old VFR fell off its side stand. I reversed the bike out of the shed, put it on the side stand and turned around to close the shed doors only to hear the sickening sound of 240kg of bike toppling onto our stone drive. I'd noticed that the side stand holds the bike very upright and I had to be careful when parking it on uneven surfaces but thought I'd been careful this morning. My shiny new bike now has nasty scrapes down the side panels but is otherwise intact. Has anyone else had problems with the angle the side stand holds the bike at? Can it be adjusted to tilt the bike further over? Sent from my iPad using Tapatalk Link to comment Share on other sites More sharing options...
Member Contributer Sparrow75 Posted September 10, 2015 Member Contributer Share Posted September 10, 2015 Feulex, so sorry to hear that. Got a bit of a knot in my gut just reading that, as I recently bought a new bike as well. Good to hear nothing major broken. Link to comment Share on other sites More sharing options...
Member Contributer Rectaltronics Posted September 10, 2015 Member Contributer Share Posted September 10, 2015 This morning my eight day old VFR fell off its side stand. I reversed the bike out of the shed, put it on the side stand and turned around to close the shed doors only to hear the sickening sound of 240kg of bike toppling onto our stone drive. I'd noticed that the side stand holds the bike very upright and I had to be careful when parking it on uneven surfaces but thought I'd been careful this morning. My shiny new bike now has nasty scrapes down the side panels but is otherwise intact. Has anyone else had problems with the angle the side stand holds the bike at? Can it be adjusted to tilt the bike further over? Ouch. Sorry to hear that. All motorcycles are going to be a bit iffy when on uneven ground or inclines on their sidestands. Or on any stands. I have not had this problem you describe but I think I have come close. That is, I have noticed once or twice where I failed to fully deploy the side stand, and noticed that it would easily have led to the bike sneaking forward and tipping over had I not been sufficiently attentive. When the side stand is deployed correctly it seems quite secure to me. I don't think there's any way to adjust the stand without getting creative. You could probably sand/grind off some metal where the hinge is to make the side stand open further forward if you wanted. Look closely at how the stand stops rotating about its hinge to figure out what I'm talking about. But don't do too much! It's a one-way street unless you have a welder, or you want to glue steel shims in there! But however much you grind, you still have to make sure the stand deploys securely before you hop off. There are adjustable stands "out there." Google turns up several options. Not sure which, if any, would be an easy fitment to the VFR. Perhaps someone here will know more. Otherwise you'd have to search around, maybe send a few emails. Link to comment Share on other sites More sharing options...
dogman Posted September 11, 2015 Share Posted September 11, 2015 Surprised to hear that. Is the bike lowered? Mine sits at quite an angle on the sidestand. If I hold the bike upright, there is a good 20mm + under the sidestand, and I often put a piece of 16mm timber under the sidestand when parked in my shed so that it doesn't lean at such a dramatic angle, and I have my forks raised 10mm through the triples as well. Link to comment Share on other sites More sharing options...
Guest Posted September 11, 2015 Share Posted September 11, 2015 Mine does not have any problems standing on the sidestand,honda does type in the manual toat it is recomended to have the wheel turned full left when using the sidestand for extra weight to that side.. Link to comment Share on other sites More sharing options...
Member Contributer fink Posted September 11, 2015 Member Contributer Share Posted September 11, 2015 Was Thinking the same too. Have never had any problems with the side stand and it does lean over a bit and I park mine on rough ground most of the time. Link to comment Share on other sites More sharing options...
emil Posted September 11, 2015 Share Posted September 11, 2015 I'm surprised about this as well. The stand is far better than my NC700's, which has a very short dead center and can easily snap back, almost causing me to drop the bike on several occasions. Link to comment Share on other sites More sharing options...
Allyance Posted September 11, 2015 Share Posted September 11, 2015 I find my 8th does stand more upright than my 83, I always make sure pavement slopes up on right side to add to lean angle when parking in unfamiliar areas. Link to comment Share on other sites More sharing options...
750 Posted September 11, 2015 Share Posted September 11, 2015 I have not had this problem you describe but I think I have come close. That is, I have noticed once or twice where I failed to fully deploy the side stand, and noticed that it would easily have led to the bike sneaking forward and tipping over had I not been sufficiently attentive. It would topple over onto it's left hand side in a case like this, I'm assuming the OP's bike fell over to the left due to him mentioning the bike standing too upright. Sorry to read about the damage by the way OP! Absolutely gutting isn't it, I dropped my absolutely pristine 750 when taking it off the centre stand, ended up getting the whole bike resprayed haha! Link to comment Share on other sites More sharing options...
ericbthomas22 Posted September 11, 2015 Share Posted September 11, 2015 Yes it is true that the side stand is to upright on my 2010 VFR . I got a ticket for speeding in New Hampshire, pulled over and parked a bit as cue. Right in front of the cop the unscrached VFR tipped over. I also would like to find out if an adjustment can be done to the side stand? Sent from my SM-N915V using Tapatalk Link to comment Share on other sites More sharing options...
fuelex Posted September 11, 2015 Author Share Posted September 11, 2015 Thanks for all the replies. It sounds like there may be some variation from bike to bike. My VFR stands up very straight compared with my CB1000R which never came close to toppling on our drive. Even this morning, I noticed that the bike was starting to slide forward on the stand. I'll get it checked out at the 600 mile service next week. Sent from my iPad using Tapatalk Link to comment Share on other sites More sharing options...
barrypz Posted September 13, 2015 Share Posted September 13, 2015 I agree my 2014 is way too upright, I am very careful about using the stand. Link to comment Share on other sites More sharing options...
Member Contributer fink Posted September 13, 2015 Member Contributer Share Posted September 13, 2015 Does this look way too upright? Not to me. This was taken with bike on a level surface. Link to comment Share on other sites More sharing options...
Member Contributer Rectaltronics Posted September 13, 2015 Member Contributer Share Posted September 13, 2015 There shouldn't be any variation at all. If it's that upright and prone to walking forward I'm betting there's something stuck in there, preventing the stand from fully deploying. Link to comment Share on other sites More sharing options...
Member Contributer fink Posted September 13, 2015 Member Contributer Share Posted September 13, 2015 Or operator error. Link to comment Share on other sites More sharing options...
fuelex Posted September 14, 2015 Author Share Posted September 14, 2015 I'm just back from three days touring in the Peak District which put nearly 600 miles on the bike. As an experiment, I measured the lean angle, with the bike in the same location, before I left and when I returned. It now leans roughly three degrees more than it did (using the handy spirit level app on my phone) so I can only guess that it was the spring tension on a new bike or something blocking the stand from fully deploying. Either way, it seems better now than it was. Sent from my iPad using Tapatalk Link to comment Share on other sites More sharing options...
