Jcb121 Posted August 15, 2015 Share Posted August 15, 2015 Hey, so I just took my wheel of to get a new tyre. I've put the wheel back on, but now it's very vibey. Is there a key marking between the wheel and the hub? So the wheel only goes one way... I didn't have the wheel balanced when the new tyre was fitted, but I never have on any of my bikes. Thanks Jesse Sent from my LG-D855 using Tapatalk Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted August 15, 2015 Member Contributer Share Posted August 15, 2015 What year is your bike? Both rim (on one of the spokes methink) and the tyre will have an arrow. Also the spacers are different, but you will be strugling to fit the wheel. Link to comment Share on other sites More sharing options...
Member Contributer Cogswell Posted August 15, 2015 Member Contributer Share Posted August 15, 2015 It sounds like you're talking about a rear wheel since you mention the wheel and hub being keyed or indexed. The rear goes on in any orientation - there is no specific matching of wheel and hub. Even though you have not previously had wheels balanced does not mean you will have a good outcome in every instance. Check that the bead is seated properly on the wheel, that the tire runs true and the pressure is correct. If it were mine I would return the wheel to the installer to have the balance checked. Link to comment Share on other sites More sharing options...
Jcb121 Posted August 15, 2015 Author Share Posted August 15, 2015 It appears to have been balanced, I found some rubber padding without weights and also a weight has been removed from the non drive side. I've just pulled my wheel off and turned it 90 degrees. Maybe it'll act a bit better. Sent from my LG-D855 using Tapatalk Link to comment Share on other sites More sharing options...
Member Contributer adeyren Posted August 15, 2015 Member Contributer Share Posted August 15, 2015 "I've just pulled my wheel off and turned it 90 degrees." Front? The front also has a direction arrow. Link to comment Share on other sites More sharing options...
Jcb121 Posted August 18, 2015 Author Share Posted August 18, 2015 "I've just pulled my wheel off and turned it 90 degrees." Front? The front also has a direction arrow. haha, yeh it's pointing sideways now I was talking about the rear but all is ok now. Thanks or the input! Link to comment Share on other sites More sharing options...
