LosLobos Posted April 15, 2015 Share Posted April 15, 2015 D.I.D. 530, Motion Pro chain tool ... Sprocket Center Question is - How much and how close to service manual spec on rivet diameter do u really need to be ... Spec low is 0.219 in. High is 0.230 in. I'm at 0.215 and it will take a lot of force on the chain tool to go further - Motion Pro instruction sheet says go lightly, but there's nothing light past this point. I'd hate to mess this up and wait for another master link. Advice needed. Link to comment Share on other sites More sharing options...
SEBSPEED Posted April 15, 2015 Share Posted April 15, 2015 Give it another twist. It is hard to get the steel of the pin moving, but once it gives, it will turn more easily. The most important thing is to make sure you remain squared up with the tool against the chain when you peen the rivet. If the tool is at an angle to the chain, your peen will shift off center and likely crack the rivet. Link to comment Share on other sites More sharing options...
Member Contributer Mohawk Posted April 15, 2015 Member Contributer Share Posted April 15, 2015 Master link rivet is rolled NOT peened, all factory links are peened. Ensure you have the correct roll pin on the vice tool & NOT the link removal pin ! many people have complained that the tools they bought are useless, when they broke them on the factory links & didn't realise that only one link plate is the master link that the tools are designed to work with. To aid inspection & location I paint the master link black, so a quick spin of the wheel & its easy to find ! YMMV Link to comment Share on other sites More sharing options...
LosLobos Posted April 16, 2015 Author Share Posted April 16, 2015 Master link rivet is rolled NOT peened, all factory links are peened. Ensure you have the correct roll pin on the vice tool & NOT the link removal pin ! many people have complained that the tools they bought are useless, when they broke them on the factory links & didn't realise that only one link plate is the master link that the tools are designed to work with. To aid inspection & location I paint the master link black, so a quick spin of the wheel & its easy to find ! YMMV Correction noted - and good idea re. the blak paint. Is the factory master link marked ? I just picked random, angle grinder rivet head, pushed out with chain tool pin. Give it another twist. It is hard to get the steel of the pin moving, but once it gives, it will turn more easily. The most important thing is to make sure you remain squared up with the tool against the chain when you peen the rivet. If the tool is at an angle to the chain, your peen will shift off center and likely crack the rivet. Done - took it to 0.224; I think that should hold. Link to comment Share on other sites More sharing options...
Shinigami Posted April 16, 2015 Share Posted April 16, 2015 Factory master link will be the one with the two peened rivets. All other rivets are staked on a normal chain. When breaking a chain it doesn't matter which one you push if you grind the heads, but it certainly matters if you don't grind first. Link to comment Share on other sites More sharing options...
