fstaRocka Posted November 21, 2014 Share Posted November 21, 2014 Hi all. Just read thru this article and it sounds allot like my problem http://www.vfrdiscussion.com/forum/index.php/topic/72644-4th-gen-clutch-issues/page-6 When i goto 3rd it starts slipping in and out of gear making a grinding noise.. 1,2,5,6 are OK.. With 1 and 2 perfect.. When the bike idles and i lean it left and. Right the noise changes to a light rattle inside. I have a spare motor, will be first time crackinga trans issue in many yrs. Any ideas? One mech said sometimes the trans wears into the cover and i should shim it or something. Do i have to drop motor to split case? Tx Link to comment Share on other sites More sharing options...
fstaRocka Posted December 10, 2014 Author Share Posted December 10, 2014 I pulled engine and split crank case, found 3rd gear fork eaten away on one side- replaced fork and one set of gears and all is perfect! FYI the clutch slipping feeling were my carbs, 3 of my 4 pilot jets were blocked causing a surging feeling. Cleaned and the bike is running strong now. Link to comment Share on other sites More sharing options...
VFR4Lee Posted December 12, 2014 Share Posted December 12, 2014 You make it sound easy. I'm sure it's not. Good deal. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted December 12, 2014 Member Contributer Share Posted December 12, 2014 Link to comment Share on other sites More sharing options...
