Member Contributer Rovari Posted November 1, 2014 Author Member Contributer Share Posted November 1, 2014 I have the markings on my 99 as well. I have resolved the problem...no more marks...just reflections... I really appreciate all of your input. Cheers Link to comment Share on other sites More sharing options...
Member Contributer zoomzoom Posted November 1, 2014 Member Contributer Share Posted November 1, 2014 Mine also had similar marks on the top of the case in behind the shock. When I was swapping in my DMr replacement shock I noticed and scrubbed them off along with the road tar and other slime that had built up over the years. Link to comment Share on other sites More sharing options...
Member Contributer Mohawk Posted November 1, 2014 Member Contributer Share Posted November 1, 2014 The starter will give you the rpm if you remove all 4 plugs & put a compression tester in one ! Link to comment Share on other sites More sharing options...
Member Contributer Ranger77 Posted November 1, 2014 Member Contributer Share Posted November 1, 2014 Dry test is what you want to do first. Wet test is only to see what kind of ring leakge you have. If you do a wet test first then you wont know whats going on. If the psi barely goes up when doing a wet test than the rings are doing their job. If it goes up a bunch then you have blow-by. Of course youre not going to have 100% sealage. You can have lower compression and not burn oil. Just depends on how the rings settled in and if your valves are closing all the way. Link to comment Share on other sites More sharing options...
Member Contributer Rovari Posted November 1, 2014 Author Member Contributer Share Posted November 1, 2014 The starter will give you the rpm if you remove all 4 plugs & put a compression tester in one ! Thank you Mohawk, that's great. I will be using a new fully charged battery so it should be fine. Dry test is what you want to do first. Wet test is only to see what kind of ring leakge you have. If you do a wet test first then you wont know whats going on. If the psi barely goes up when doing a wet test than the rings are doing their job. If it goes up a bunch then you have blow-by. Of course youre not going to have 100% sealage. You can have lower compression and not burn oil. Just depends on how the rings settled in and if your valves are closing all the way. Thank you Rangerscott, good point and good thing you mentioned it, now i will try both dry and wet..but dry first. Link to comment Share on other sites More sharing options...
Member Contributer Ranger77 Posted November 2, 2014 Member Contributer Share Posted November 2, 2014 Engine needs to be fully warmed up too. Link to comment Share on other sites More sharing options...
