Member Contributer DFerrell Posted September 14, 2014 Member Contributer Share Posted September 14, 2014 SW Motech with Givi's. I've been thinking about getting a high mount but I'm wondering if it will fit with the bags and racks. TIA I could do some mods if needed. Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted September 14, 2014 Member Contributer Share Posted September 14, 2014 looks like you have enough space fo a hi mount, with a bit of luck the S-pipe will fit. else some modifications are required.... http://www.vfrdiscussion.com/forum/index.php/topic/75608-vfr750-st-pan-dutchopean/ Link to comment Share on other sites More sharing options...
Guest Posted September 14, 2014 Share Posted September 14, 2014 Easier if you get the top rack. It will take about an hour with the right tools. I used a steel bar from Tractor Supply. Drilled,tapped and beveled each end. The top horizontal supports I extended and inch on the left and two on the right. No need to do the left, but it matches a little better if you do. When complete I wrapped the steel in black heat shrink once heated it gave everything a nice black rubbery feel. Link to comment Share on other sites More sharing options...
marriedman Posted September 14, 2014 Share Posted September 14, 2014 On the 5th gen it is so easy to change the can. I had a high mount and a low mount that I would switch when I was touring. Sent from my LG-D801 using Tapatalk Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted September 14, 2014 Member Contributer Share Posted September 14, 2014 Gr8vfr, how wide is that rear? Link to comment Share on other sites More sharing options...
Guest Posted September 14, 2014 Share Posted September 14, 2014 41 inches. Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted September 14, 2014 Member Contributer Share Posted September 14, 2014 good, your azz is as fat as mine then Link to comment Share on other sites More sharing options...
MuskokaMike Posted September 14, 2014 Share Posted September 14, 2014 Here's what I came up with!! Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted September 14, 2014 Member Contributer Share Posted September 14, 2014 THAT is ingenious!!! Never seen before! Only for the one's among us who are gymnastic/elastic though!!! Link to comment Share on other sites More sharing options...
Member Contributer zupatun Posted September 14, 2014 Member Contributer Share Posted September 14, 2014 My SW motech mount and Givis are the same. Looked at trying mod w hi mount years ago. For my needs, low mount works just fine, I having two pipes is easiest... Link to comment Share on other sites More sharing options...
