jaydj Posted September 6, 2014 Share Posted September 6, 2014 So I used to be able to start by VFR in gear (like if I stalled at a light), but now I have to shift into neutral to start it. Anyone have a similar issue and solution. Curious if this is a sign of dreaded electrical problems to come as my bike approaches 63,000mi. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted September 6, 2014 Member Contributer Share Posted September 6, 2014 After market levers ? Link to comment Share on other sites More sharing options...
jaydj Posted September 6, 2014 Author Share Posted September 6, 2014 Nope -- stock Link to comment Share on other sites More sharing options...
Lee 2002 Posted September 6, 2014 Share Posted September 6, 2014 Clutch switch. Still stalling at stoplights after 63,000 miles? Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted September 6, 2014 Member Contributer Share Posted September 6, 2014 Short the two wires together at the clutch lever and see if it will start in gear . Link to comment Share on other sites More sharing options...
Member Contributer FJ12Ryder Posted September 6, 2014 Member Contributer Share Posted September 6, 2014 Might also check the sidestand interlock. That kills the engine if you put it in gear with the sidestand down. Nope, forget that because it wouldn't even run at all. So never mind. Link to comment Share on other sites More sharing options...
Lee 2002 Posted September 6, 2014 Share Posted September 6, 2014 Short the two wires together at the clutch lever and see if it will start in gear . Yeah, this ^ would be a really dumb idea unless you also to bother to pull in on the clutch lever at the same time..... unless you want your motorcycle laying on it's left side. Use a multimeter to check the function of the clutch switch. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted September 7, 2014 Member Contributer Share Posted September 7, 2014 Short the two wires together at the clutch lever and see if it will start in gear . Yeah, this ^ would be a really dumb idea unless you also to bother to pull in on the clutch lever at the same time..... unless you want your motorcycle laying on it's left side. Use a multimeter to check the function of the clutch switch. Common sense for most riders but for you next time I will be sure and write a common sense disclaimer. Short the two wires together at the clutch lever and see if it will start in gear . Let me update this in case you dont know that you have to pull the clutch in to try this. Lee 2002 common sense disclaimer added . Hot dam that's funny . Link to comment Share on other sites More sharing options...
