signal Posted September 1, 2014 Share Posted September 1, 2014 Today when replacing my front tire, I noticed my right side pinch bolt threads were stripped. I could not put the bolt back on because there were no threads to catch it. So I ended up doing my first helicoil. I got the kit at Advanced Auto Parts. Drilled, tapped, inserted coil, and it works GREAT! I used plenty of cutting oil, and only tapped a few turns at a time, backing out and cleaning it all up. Good as new! Link to comment Share on other sites More sharing options...
SEBSPEED Posted September 1, 2014 Share Posted September 1, 2014 Good job. Certainly more elegant a solution than a longer bolt with a nut on the end would have been. Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted September 1, 2014 Share Posted September 1, 2014 That is the preferred method. The longer bolt and nut is more of a farmer fix, but can be done. And/or drilling out to the next larger size and tapping accordingly, but then you are making the parent material thinner also............ Link to comment Share on other sites More sharing options...
