ljmellor Posted July 15, 2014 Share Posted July 15, 2014 I recently ordered a full set of brake seals from M&P via fleabay, when they landed I was greeted with 6 seals and 6 dust seals, as far as I'm aware there are 9 pistons in total, does anyone have any idea what part numbers I should've received as my complaint about not getting enough parts has led them to ask me which part numbers I need. Not being a bike parts supplier (like M&P it seems) I am not sure, much googling has turned up nothing. I want to fit my new goodridge hoses but it would make sense to do the seals at the same time... Link to comment Share on other sites More sharing options...
Member Contributer MBrane Posted July 16, 2014 Member Contributer Share Posted July 16, 2014 I remember going through the fiche when I did mine, and after double & triple checking still ended up with the wrong count. You are right there are 9 pistons, but they are different sizes. It's been a while, but I think I ordered too many of one size, and not enough of the other. A little investigating on a parts site with a good fiche will likely turn up which ones you need. The part #s should be on the bags you have. The fiche on http://www.rockymountainatvmc.com/oem-schematic/5 shows the bore sizes of the pistons when you mouse over 'em. Link to comment Share on other sites More sharing options...
Member Contributer AnikMankar Posted July 16, 2014 Member Contributer Share Posted July 16, 2014 i think you have received only the front seals. try... Rear 06431-MA3-405 x 1 - Rear Center - HONDA CODE 4124277 06451-MZ2-405 x 2 - Rear outer - HONDA CODE 4179362 Front 06431-MA3-405 x 1 - Front - HONDA CODE 4124277 06451-GE2-405 x 2 - Front - Honda Code 4102174 06451-MZ2-405 x 3 - Front Center/outer- HONDA CODE 4179362 This is for my 1998 ...i am assuming it should be same. Link to comment Share on other sites More sharing options...
ljmellor Posted July 16, 2014 Author Share Posted July 16, 2014 I think you may be right as I did get 3 of one, 2 of another and one of another. Getting sick of their useless customer support, can anyone recommend a good place to buy them from quickly and reliably in the UK? I'm going to send these back for refund as for allI know I could have seals for a sherman tank based upon their reluctance to admit what they advertised compared to what they sent out. Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted July 16, 2014 Member Contributer Share Posted July 16, 2014 http://www.davidsilverspares.co.uk/VFR800FIX-1999/ Link to comment Share on other sites More sharing options...
Member Contributer AnikMankar Posted July 16, 2014 Member Contributer Share Posted July 16, 2014 you can also check - http://www.cmsnl.com do compare the prices Link to comment Share on other sites More sharing options...
