Instrument Faceplate Change
AnikMankar
Hi
have purchased a custom instrument cluster/faceplate. Any one has changed these ? anything to lookout for before i dismantle it.
* alignment of the Zero ?
* removal of the needles ?
do let me know guys - thanks in advance
http://i.ebayimg.com/00/s/NTAwWDkwMA==/z/rAIAAOxyGstR9u25/$(KGrHqZHJEUFHWNZWDJ0BR9u24i+8Q~~60_57.JPG
Anik
Hey Anik
There was a member on VFRW that replaced his gauge faces with ones just like those in your link. As I recall, he didn't have any real issues with the swap. Check out the link.
http://vfrworld.com/forums/showthread.php/44026-New-gauge-faces
Hi they look sweet.
Who is the seller out of interest?
if you are referring to the back plate - they are on eBay. I am planning to incorporate a volt meter in there also. Not yet received the volt meter, untill then...
Hi they look sweet.
Yeah it is the backplate. Do you know who the seller is, can't find them.
  • 3 weeks later...
Hey v4pilot
What is the "0" located in the bottom of your gauge cluster? Is it a gear indicator, or voltmeter perhaps?
Yep it means its in neutral at the moment; I stuck a gear ind. where the neutral light was.
done something similar but not as clean as yours. Have placed it outside . Still needed the Neutral light to ensure i have the gear in that position
IMG 20120116 00123
IMG 20120116 00124
My plan is to put the voltmeter in the faceplate.
These are the custom plates I got ...
thanks Anik
Will figure out which Looks the best
thanks Anik
thanks Anik
These are about 4mm thick. Would require some alterations. Will know only after I take them apart.
Have searches around for good pictures of already opened up instruments. Quite difficult.
thanks Anik
Some progress
RPM side. Didn't find any space or a good location for the volt meter. So installed the faceplate as is.
Needle stop hole being too big, had to super glue that needle and secured it with some silicon on the rear side.
Rpm side completed
Speedo side top side has some place
Photo copy of the speedometer faceplate helped to create the right stencil and position.
The unit underneath is protruding out so had to move the volt meter up by 1mm
The faceplate sits on a plastic light defuser. This spreads the light from the bulbs. Marked this plates also as it needs to be cut.
Once Marked, masked the area as it needs to be cut off. Used a soldering iron to cut it off found it less messy.
Similarly the faceplate had to be cut of. This was tough as it is soft can't file or dremil it. Used a sharp blade
There is a slight gap and the light will defuse through the gap. A little black paint and silicon to seal it of.
More later.
thanks Anik
Very nice. Can I send you mine and about 30 of my friends face plates .
Nice work ..
sure anytime :) all the way to this side of the planet !!
Some more progress..
20140417 091504
Noticed the bulb connectors are loose - looks like the printed circuit is worn out making the lights flicker sometimes.
Anyone fixed these using electric circuit pens ? any other options besides soldering a fresh circuit on top of it. ?
No clue
I have rebuilt the circuit using just solder. Hope it works
This is how it looks. The end points where the bulb holder stops is pitted hence causing loose contact
Got them polished using a polish pen.
Polish pen is just like sand paper but in pen style. The tips are fiber
Finally got them soldered.
Hope it works
thanks Anik
