Guest kayaktom Posted May 20, 2012 Share Posted May 20, 2012 Hi all, I thought someone might benefit from a few photos of the electrical additions I made to my '95 this weekend, mainly because I when was looking for photos of options I didn't find too much. First the Blue Sea Systems 6-circuit fuse block mounted under the seat near the tail end of the bike. There's a relay near the battery, so all the circuits are switched power. It makes for longer wiring runs, but a fairly clean install, and I like having accessories on switched power. Next was the powerlet socket, installed on the left middle fairing, where it will be out of the way for heated gear, or a run up to a tank bag or RAM mounted GPS. I didn't care for the steering stem mount for the heated vest since the cord would run across the tank. There's really no weight on the setup, so I'm not too worried about stressing the ABS. Finally, the SD heads-up LED display, mounted on the inside of the left windshield support area, near where the mount for the mirror is. I wanted it noticable, but not part of the main dash, particularly if it becomes a distraction and I want to take it out later. Unlit: Lit: Hope this helps someone looking for mounting/install ideas. There's a more detailed write-up here: http://kayaktom.com/.../#!lightbox/2/. - Tom Link to comment Share on other sites More sharing options...
Guest Posted May 21, 2012 Share Posted May 21, 2012 You should have hidden it. I have mine in the left vent under the seat. I put a toggle switch for the heated grips in the left side of the upper. It is extremely hard for me to drill the stock plastic. Once you do it, there is a hole forever. And 18-16 year old fairing panels are so hard to find in good condition. Link to comment Share on other sites More sharing options...
Member Contributer slowbird Posted May 22, 2012 Member Contributer Share Posted May 22, 2012 Good work! I added my LED HUD to the Dash right under the windscreen. That little rubbery plasticy bit. Just punched a whole thru it. Link to comment Share on other sites More sharing options...
Member Contributer realistdreamer Posted May 22, 2012 Member Contributer Share Posted May 22, 2012 Bah! Drilling things is great fun. Although I did scuff up the plastic on the grips install. Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted May 22, 2012 Member Contributer Share Posted May 22, 2012 For the Powerlet socket I made a small bracket and fitted it near the oem fusebox. Link to comment Share on other sites More sharing options...
