SEBSPEED Posted December 9, 2010 Share Posted December 9, 2010 Found this while perusing the internet - use the info at your own risk. http://www.vintagebrake.com/mastercylinder.htm Quote Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted December 9, 2010 Share Posted December 9, 2010 Beware that VFR 800 calipers front and rear, all years, use different sized pistons, so you would have to calculate your own total surface area independently, say of you were planning on de-linking the brakes. . Quote Link to comment Share on other sites More sharing options...
SEBSPEED Posted December 9, 2010 Author Share Posted December 9, 2010 Beware that VFR 800 calipers front and rear, all years, use different sized pistons, so you would have to calculate your own total surface area independently, say of you were planning on de-linking the brakes. . Good to know! :fing02: Quote Link to comment Share on other sites More sharing options...
Member Contributer VF1000RS Posted December 9, 2010 Member Contributer Share Posted December 9, 2010 RC51 uses 2 different size front pistons all years and early years are larger sizes than later years. Quote Link to comment Share on other sites More sharing options...
Member Contributer Vee-Ef-Ar Posted December 10, 2010 Member Contributer Share Posted December 10, 2010 Grabbed this from RC51forums.com when I saw the specs: The SP1 Has a 19mm Master Cylinder & Runs a 34/32 Piston Calipers. On the SP2, it has a 17mm Master Cylinder & Runs a 32/30 Piston Calipers. It is important to note that if you are fitting SP1 calipers, they will need to be installed with their corresponding carrier (mount)... and vice versa for SP2. This is due to offset the different sized pistons. Quote Link to comment Share on other sites More sharing options...
