Guest vice Posted October 22, 2009 Share Posted October 22, 2009 First time poster here. The story.... Bought a 2003 VFR several months ago. Bike has been great, no problems. Starts everytime, no hesitation. Smooth, lights are bright. Took it out for a spin yesterday. Went to lunch, and when I came back out to start, the bike would barely turn over. Eventually, after trying to start it several times, the bike would not turn over at all. Every time I turn the ignition on now, the fuel pump kick on AND the clock resets itself to 1:00 am. Bike will not start. I currently have the battery on a charger. Here's what I know: 1. Previous owner installed a new battery last year. 2. Wiring harness recall has been DONE. I checked the 30 amp fuse and it was not blown. Reading and searching here on VFR Discussion, it could be the R/R? Just wanted to get opinions as to what steps I should take. Thanks in advance! Greg Link to comment Share on other sites More sharing options...
Member Contributer jeremy556 Posted October 22, 2009 Member Contributer Share Posted October 22, 2009 Charge the battery, see if the the bike starts with it. If it does not start, take the battery to a battery store or auto parts store and have it load tested to rule it out. With the battery verified and fully charged, put a multi meter on it and see what the charging voltage is at idle and at 5500RPM with the bike warmed up. It should be in the 13.8-15 volt range. Post back with your results. If it is under 13.8 then you will begin testing the stator, if it is over 15 volts you will begin with the R/R and wiring, if it is within spec, check for parasitic loss when the key is off. Link to comment Share on other sites More sharing options...
Baileyrock Posted October 22, 2009 Share Posted October 22, 2009 What he said! :huh: Link to comment Share on other sites More sharing options...
Tightwad Posted October 22, 2009 Share Posted October 22, 2009 :cool: to both...remember the R/R will not stop it from starting, but it WILL stop it from re-starting if it doesn't charge the battery. Link to comment Share on other sites More sharing options...
Guest Posted October 24, 2009 Share Posted October 24, 2009 OK. Charged the battery, and installed it back in the bike. VFR started right up. Let it warm up. Tested at idle, 14.42 volts. Tested at 5500 rpm, 14.43 volts. I did take the battery and have it tested and they said it was OK. Hmm. How do I check for "parasitic losses"? Thanks again! Link to comment Share on other sites More sharing options...
Member Contributer Alien VFR Posted October 24, 2009 Member Contributer Share Posted October 24, 2009 ...Welcome to VFRD... Link to comment Share on other sites More sharing options...
Member Contributer Ryanme17 Posted October 24, 2009 Member Contributer Share Posted October 24, 2009 How do I check for "parasitic losses"?Thanks again! Turn the brights on, the brake lights, turn signals, etc. Out of curiosity, what does the battery read with the bike off? Your charging voltage sounds good, and your battery tested okay, so why would it die that one time? Is it running fine now? Link to comment Share on other sites More sharing options...
Member Contributer sckego Posted October 24, 2009 Member Contributer Share Posted October 24, 2009 How do I check for "parasitic losses"?Thanks again! Turn off the bike and disconnect the wire going to the negative terminal of the battery (leave the positive terminal attached). Put an ammeter between the wire and the neg terminal. This will tell you the amount of current leakage that the battery is losing while the bike is off. The leakage should be less then 2.5 mA. Any more and you risk the leakage just draining the battery while it's not being ridden. Link to comment Share on other sites More sharing options...
Guest Posted October 31, 2009 Share Posted October 31, 2009 Just wanted to say "Thanks" for all the help! Link to comment Share on other sites More sharing options...
