My '98 came with heated grips that are OK, the wires have been run from the switch, etc., but not hooked up to the battery and a relay trigger point. I want to hook them up. Here's a photo of what I've got:
The photo shows a 3-wire bundle coming from the left side of the bike (bottom of photo) - 2 red wires and 1 black wire.
The red wire that exits to the left over the battery compartment lid is simply cut (ending on the PCIII).
The black wire goes up to the blue round fitting, which fitting also contains a separate smaller gauge black wire that heads to the right (across the PCIII), to the relay, attaching to terminal 85.
The second red wire from the 3-wire bundle goes off to the right and attaches to the relay at terminal 87.
Coming from the relay (from terminal 30) is a red fused hot wire (has the yellowish connector just to the left of the PCIII).
I'm not sure how all of this terminal stuff works, but I probably am correct that the fused red line from the relay goes to the battery positive terminal. Similarly, I probably am correct that the black wire ending in the blue connector goes to the battery negative terminal. I assume the wires at/on the relay are where they need to be. If I'm wrong, let me know.
What I'm unsure about is the first red wire coming from the wire bundle (that handles the grips/switch at the front of the bike) that is clipped, and what wire, if NOT that red wire, is attached a taillight hot wire to trigger the relay. It seems to me such a trigger wire should come from the relay and go to the hot wire??
If it is that clipped red wire, is establishing a relay trigger simply a matter of hooking that wire to a positive hot wire at a taillight or license plate light? If so, is a separate ground needed?
Follow up question: I'd like to run a voltmeter off of the grip wiring under the cowl that would work even when the grips were off. There are several wires up there, going to the switch and grips, and so I wonder what red/black wires I should be looking at to tap for the gauge.
Question
Misspent Youth
Thanks for any help.
7 answers to this question
