Guest mikeym Posted April 25, 2008 Share Posted April 25, 2008 Hey Guys, Title says it all... My dashlights and my headlights change brightness when I blip the throttle... It hasn't been a problem so far, but I've only owned my VFR for 2 months. Should I be preparing for a R/R failure or getting ready to rip into the stator? ~mikeym Link to comment Share on other sites More sharing options...
Member Contributer captainchris13 Posted April 25, 2008 Member Contributer Share Posted April 25, 2008 stop riding it. NOW. take a Voltage meter to it, if it goes high (it will spike up over 15 if its bad) its already blown. get the 6th gen one and follow the instructions elsewhere on this site to replace it. you can damage the computer other things by running overvoltage. Link to comment Share on other sites More sharing options...
Guest Posted April 25, 2008 Share Posted April 25, 2008 stop riding it. NOW. take a Voltage meter to it, if it goes high (it will spike up over 15 if its bad) its already blown. get the 6th gen one and follow the instructions elsewhere on this site to replace it. you can damage the computer other things by running overvoltage. oh smooth... where do I connect the voltage meter? I'm down at college right now... I'll be returning home this weekend (hour ride)... I'm probably going to replace with a R1 unit and do the mod I have seen on other threads... For the time being if I am not spiking over 15, I'm just going to ride with it. I'd like to install a fan this weekend however... Can the fan be installed with enough space to mount the R/R underneath the seat cowl? ALSO Will CBR units be plug and play? ~mikeym Link to comment Share on other sites More sharing options...
Member Contributer CitizenOfDreams Posted April 25, 2008 Member Contributer Share Posted April 25, 2008 Fix it NOW, or you may be preparing to replace the battery, all the bulbs, ECU and instruments. Put the voltmeter right on the battery terminals and measure the voltage while the engine is running at 4000 RPM or so. While you're there, check the battery terminals for corrosion and looseness. Link to comment Share on other sites More sharing options...
Member Contributer thereisnospoon Posted April 25, 2008 Member Contributer Share Posted April 25, 2008 Hey Guys,Title says it all... My dashlights and my headlights change brightness when I blip the throttle... It hasn't been a problem so far, but I've only owned my VFR for 2 months. Should I be preparing for a R/R failure or getting ready to rip into the stator? ~mikeym Well, you need to check voltage, but if your are blipping from a low idle there will be a voltage change, mine doesn't put out over 13.5 at idle but will jump to a little over 14 by 2000 rpms or so. The yellow (2000) ones didn't have the reg/rect problems the other colors did (except 2001) Link to comment Share on other sites More sharing options...
Guest Posted April 25, 2008 Share Posted April 25, 2008 Hey Guys,Title says it all... My dashlights and my headlights change brightness when I blip the throttle... It hasn't been a problem so far, but I've only owned my VFR for 2 months. Should I be preparing for a R/R failure or getting ready to rip into the stator? ~mikeym Well, you need to check voltage, but if your are blipping from a low idle there will be a voltage change, mine doesn't put out over 13.5 at idle but will jump to a little over 14 by 2000 rpms or so. The yellow (2000) ones didn't have the reg/rect problems the other colors did (except 2001) I also heard this year didn't have the voltage problems. I believe this is probably normal, but I will check it with a voltmeter tomorrow. ~mike Link to comment Share on other sites More sharing options...
Member Contributer Rivcyko Posted April 25, 2008 Member Contributer Share Posted April 25, 2008 Hey Guys,Title says it all... My dashlights and my headlights change brightness when I blip the throttle... It hasn't been a problem so far, but I've only owned my VFR for 2 months. Should I be preparing for a R/R failure or getting ready to rip into the stator? ~mikeym Well, you need to check voltage, but if your are blipping from a low idle there will be a voltage change, mine doesn't put out over 13.5 at idle but will jump to a little over 14 by 2000 rpms or so. The yellow (2000) ones didn't have the reg/rect problems the other colors did (except 2001) I also heard this year didn't have the voltage problems. I believe this is probably normal, but I will check it with a voltmeter tomorrow. ~mike LOL. They all do. Just a question of choosing your poison. Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted April 25, 2008 Member Contributer Share Posted April 25, 2008 I believe this is probably normal, ~mike How did good old Lenin put it? "Trust is good, control is better"..... :fing02: Link to comment Share on other sites More sharing options...
Member Contributer thereisnospoon Posted April 25, 2008 Member Contributer Share Posted April 25, 2008 Hey Guys,Title says it all... My dashlights and my headlights change brightness when I blip the throttle... It hasn't been a problem so far, but I've only owned my VFR for 2 months. Should I be preparing for a R/R failure or getting ready to rip into the stator? ~mikeym Well, you need to check voltage, but if your are blipping from a low idle there will be a voltage change, mine doesn't put out over 13.5 at idle but will jump to a little over 14 by 2000 rpms or so. The yellow (2000) ones didn't have the reg/rect problems the other colors did (except 2001) I also heard this year didn't have the voltage problems. I believe this is probably normal, but I will check it with a voltmeter tomorrow. ~mike LOL. They all do. Just a question of choosing your poison. :fing02: that was the scene you picked from that movie??? did you see her walking around towards the beginning of the movie? :p Link to comment Share on other sites More sharing options...
Guest Posted April 25, 2008 Share Posted April 25, 2008 holy off topic batman! Well, I'm gonna check the regulator tomorrow. I have a deal on an 02 R1 unit that I'm going to throw on here if this doesn't work. If the regulator is fine, do you guys have a link to the "fan" mod for the stock unit? ~mikeym Link to comment Share on other sites More sharing options...
Member Contributer CitizenOfDreams Posted April 26, 2008 Member Contributer Share Posted April 26, 2008 If the regulator is fine, do you guys have a link to the "fan" mod for the stock unit? Don't waste your time, a fan is not going to do a darn thing to keep the regulator from burning up. Link to comment Share on other sites More sharing options...
Guest Posted April 29, 2008 Share Posted April 29, 2008 If the regulator is fine, do you guys have a link to the "fan" mod for the stock unit? Don't waste your time, a fan is not going to do a darn thing to keep the regulator from burning up. Well I did it anyway... I checked the voltage this past weekend... It never dropped lower than 13.5 and didn't peak higher than 14.5 I figured i'd throw a fan on it to keep it cool... I'll have to post up some pictures when I return to my residence... Link to comment Share on other sites More sharing options...
Guest Posted April 29, 2008 Share Posted April 29, 2008 Hey guys, I heard often about R/R problems. I'm just not sure if I'm concerned with my 2001. Should I ? Thanks Link to comment Share on other sites More sharing options...
Member Contributer Rivcyko Posted May 18, 2008 Member Contributer Share Posted May 18, 2008 Hey guys,I heard often about R/R problems. I'm just not sure if I'm concerned with my 2001. Should I ? Thanks I would. Link to comment Share on other sites More sharing options...
