Guest optiman Posted July 18, 2007 Share Posted July 18, 2007 Hello I'm a new member who is picking up a Black 06 from dealer tomorrow. Bike has 2400 miles and looks great! It includes Sargent seat, Heli risers,Laser Extreme pipes,unknown tinted shield(larger than OEM),aftermarket levers and stainless bar ends. This type of bike is new to me, so what items should I look for that might have a problem. I don't want to drive it off the lot before the bike is inspected for common problems that I'm not aware of and dealer does not want to acknowledge. Any input from the members would be helpful. Thanks, OPTIMAN Link to comment Share on other sites More sharing options...
Member Contributer dutchinterceptor Posted July 18, 2007 Member Contributer Share Posted July 18, 2007 Congrats! Make sure the kickstand bolt is tight and check the 30 amp fuse holder and wire next to the battery for melting/burning. That's all I can think of at the moment. Link to comment Share on other sites More sharing options...
Member Contributer FotoMoto Posted July 18, 2007 Member Contributer Share Posted July 18, 2007 Umm, oil!! (see another thread). Sounds like a great specimen. Nothing really comes to mind other than the typical inspection (no recalls, etc). Link to comment Share on other sites More sharing options...
Member Contributer Spike Posted July 18, 2007 Member Contributer Share Posted July 18, 2007 Have the Dealer pull off the seat and fairings. Check to see if the electrical is cobbled together (someone in Hawaii had an issue with this a few weeks ago), like dutchinterceptor said check for burnt wiring/connectors around the battery, verify the toolkit is in place. Bring someone along that knows motorcycles. Are the passenger seat cover, grab handles and handle mount covers included? Ask the dealer if they aren't with the bike. Have the dealer check the tire pressures or check them before you ride. Same with chain lube. Spike Link to comment Share on other sites More sharing options...
tinyminds Posted July 18, 2007 Share Posted July 18, 2007 Hey your close to me! Welcome from Orlando. You will have to catch one of our rides some day. +1 to Foto's post. Cya around. Link to comment Share on other sites More sharing options...
SEBSPEED Posted July 18, 2007 Share Posted July 18, 2007 Have the Dealer pull off the seat and fairings. Check to see if the electrical is cobbled together (someone in Hawaii had an issue with this a few weeks ago), like dutchinterceptor said check for burnt wiring/connectors around the battery, verify the toolkit is in place. Bring someone along that knows motorcycles. Are the passenger seat cover, grab handles and handle mount covers included? Ask the dealer if they aren't with the bike. Have the dealer check the tire pressures or check them before you ride. Same with chain lube.Spike What he said, seat cover, grab rails, tool kit. Be sure to inspect the color of the fluid in the brake and clutch master cylinders; they should look like green tea, or close to it. If they look like honey or darker, make them replace the fluid. It degrades with time as well as use. Wouldn't hurt to ask to have the starter valves synched. When you get it home you may want to take a look at the condition of the fork oil. And, it should come with a full tank of gas. Any dealer worth dealing with would do this for you without being asked. :thumbsup: Link to comment Share on other sites More sharing options...
