Guest khyron Posted January 1, 2007 Share Posted January 1, 2007 I recently purchased a small box of Posi-Locks from Wal-mart. I have been concerned with the condition of the charging system connectors. I soldered most of them to get good connection, but the 3 wires coming from the stator couldn't be soldered, the wire is stainless steel so the solder doesn't cling to it when "wicking" the wire. The connector that mates those 3 wires to the R/R is usually pretty warm also, so there is alot of resistance at that connection too. Short of taking the stator off and soldering a copper wire directly to the coils(too much work) i read a posting about someone talking about Posi-Locks. All they are is a plastic cylinder that you insert the wire into and screw in the male end to lock down the wire onto a tapered piece of metal. Very simple to use. After i used these connectors, my 3 wires are not hot, the only heat is from the engine. I am very pleased with this so far, the only thing i did is to put silicone in each end to seal it up. They make waterproof ones, but i didn't like the look of them. I figured silicone will do the same job. Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted January 1, 2007 Share Posted January 1, 2007 For anyone who is wondering: http://www.posi-lock.com/ Link to comment Share on other sites More sharing options...
ULEWZ Posted January 1, 2007 Share Posted January 1, 2007 For anyone who is wondering:http://www.posi-lock.com/ Yes I was, thanks. Looks like we have a winner. Link to comment Share on other sites More sharing options...
tinyminds Posted January 1, 2007 Share Posted January 1, 2007 well @#$% i was looking for something like that yesturday when I was rewiring my entire fuse block to accessories. couldn't find anything i liked, guess i'll have to go check those out. thanks for post. Link to comment Share on other sites More sharing options...
turtlecreek Posted January 1, 2007 Share Posted January 1, 2007 thanks for the post. great info Link to comment Share on other sites More sharing options...
Guest Posted January 1, 2007 Share Posted January 1, 2007 I used these and Posi-Taps for wiring my heated grips after reading the following review on webBikeWorld: Posi-Lock Review I sealed them with silicone and also find that they work well. Link to comment Share on other sites More sharing options...
