Member Contributer Dennis The Menace Posted March 3, 2006 Member Contributer Share Posted March 3, 2006 I am finally going to put the CBR 929 shock in my 1996. I have a question for those who have already done it. Did you put the shock to stock settings before installing it? After installation, how easy is the access to change settings? Link to comment Share on other sites More sharing options...
2003_VTEC_Rider Posted March 3, 2006 Share Posted March 3, 2006 I was wondering if a 954RR or a 1000RR shock would fit in a 6th gen, hmmmm next winter project. Link to comment Share on other sites More sharing options...
SEBSPEED Posted March 3, 2006 Share Posted March 3, 2006 I was wondering if a 954RR or a 1000RR shock would fit in a 6th gen, hmmmm next winter project. <{POST_SNAPBACK}> I have a 600rr shock, and soon, an F4i shock laying around. Wonder if they would offer an improvement? The F4i has a remote res., too. Link to comment Share on other sites More sharing options...
2003_VTEC_Rider Posted March 3, 2006 Share Posted March 3, 2006 Hmmm. I wonder if they would? Wouldn't they be set up for a lower weight though? Maybe we will have to talk on a price, I wouldn't mind trying something like that out. Link to comment Share on other sites More sharing options...
Baileyrock Posted March 3, 2006 Share Posted March 3, 2006 I was wondering if a 954RR or a 1000RR shock would fit in a 6th gen, hmmmm next winter project. NO ! any shock with a fixed reservoir will Not fit on a Vtec. No room. 5th gen yes. Link to comment Share on other sites More sharing options...
Guest SagaciousDupe Posted March 3, 2006 Share Posted March 3, 2006 I have a 600rr shock, and soon, an F4i shock laying around. Wonder if they would offer an improvement? The F4i has a remote res., too. <{POST_SNAPBACK}> I have an F4i on mine...it works great ~ action is greatly improved. The spring is a bit light. I have my sag set to 32mm, but it's maxed out on the preload. I weigh 175 geared up. The shock is about 10mm shorter than the stock shock so it needs shimmed. The biggest drawback is that the preload adjuster is on the bottom of the shock and ends up inside the swingarm. It would be possible to make a tool to adjust ~ I didn't take the time to do this. (Adjusted sag when I installed by taking the shock out again) Before installing the F4i, put one end in a vice, and a large screwdriver on the other end. Rotate the shock on it's shaft 180 degrees so that the rebound adjuster is on the correct side. Shock lengths...hole to hole stock 317.5mm ~ Vtec F4i 307mm ~ preload is on bottom! 900rr 303mm ~ preload is on top! Possibility?? Dennis, sorry I have no info for your bike! Link to comment Share on other sites More sharing options...
2003_VTEC_Rider Posted March 3, 2006 Share Posted March 3, 2006 Hmmmm, and I bet I can probably find one fairly cheap around. Maybe Sebspeed wants to get rid of his, :D Link to comment Share on other sites More sharing options...
Guest SagaciousDupe Posted March 3, 2006 Share Posted March 3, 2006 I should have mentioned how I got the shock lengths... On the Ohlins web site, they have the option for 'recommendation list'. Select the make / model / year of the shock in question. Two things I looked at...the shock length, and the stroke. (making sure that the shock in question has a stroke at least as long as the stock shock) For valving, hit or miss. I just got lucky with the F4i. Maybe that can help you Dennis! Link to comment Share on other sites More sharing options...
Member Contributer Dennis The Menace Posted March 3, 2006 Author Member Contributer Share Posted March 3, 2006 I've been hijacked. Link to comment Share on other sites More sharing options...
Baileyrock Posted March 3, 2006 Share Posted March 3, 2006 I've been hijacked. Sorry Dennis, the 4th gen is one I've not worked on. :blink: Link to comment Share on other sites More sharing options...
2003_VTEC_Rider Posted March 3, 2006 Share Posted March 3, 2006 Sorry I jacked your thread, Link to comment Share on other sites More sharing options...
Auspanglish Posted May 6, 2011 Share Posted May 6, 2011 I was wondering if a 954RR or a 1000RR shock would fit in a 6th gen, hmmmm next winter project. <{POST_SNAPBACK}> NO ! any shock with a fixed reservoir will Not fit on a Vtec. No room. 5th gen yes. Pulling this one out of the anals... Are you sure of this BR?? I thought it was possible to fit a 929 shock on the VTEC... I'm about to buy one... maybe this info is out of date and it has been found that you can fit a 929er on the 6th gen... I can get my hands on a 929er with only 14000 km on it compared to the 90,000 km my OEM shocker has seen (it's a shocker of a shock... POS)... the spring rate's the same which ideally I would upgrade to a 19-20kg spring but there must be a massive improvement as is (wonder if internals should be swapped out for such a big difference in spring rate)... was also thinking of going 0,95 up front (Sonic Spings), but don't know if they're progressive or not and whether I'll have to get custom spacers made up... so many questions... I've managed to compile all this data after spending several hours viewing thread after thread: SPRING RATES VFR800 = 15.3kg/mm CBR929 = 15.3kg/mm +/- mismo recorrido 57mm Vs 58mm CBR954 = 14.6kg/mm CBR XX = 16.8kg/mm BOLT REQUIRED 5th gen = 10mm x 110-115mm grind head down for clearance (probably so for VTEC as well????) EYE-TO-EYE LENGTH OF SHOCKS (different data according to original posters) 5th gen = 325mm VTEC = 316mm / 317.5mm CBR929 = 286mm / 288mm / 287mm CBR954 = 282mm 4th gen = 324mm / 325mm SPACER 5th gen = 42mm + 1 or 2 shims (1mm thick??) 4th gen = 41.5 mm Honda adjuster wrench for 929: Part no: 89202-KY1-700 But I really need the data for the VTEC Link to comment Share on other sites More sharing options...
mrmatt Posted May 6, 2011 Share Posted May 6, 2011 If I remember right I think member JamieDaugherty recommends a stiffer spring for the 929 in the 4th gen, send him a PM as he is very familiar with this swap Link to comment Share on other sites More sharing options...
Auspanglish Posted May 7, 2011 Share Posted May 7, 2011 If I remember right I think member JamieDaugherty recommends a stiffer spring for the 929 in the 4th gen, send him a PM as he is very familiar with this swap Thanks... BR, didn't you end up slapping on a 929 shock on your VTECker?? Link to comment Share on other sites More sharing options...
