mavevans99 Posted April 20, 2023 Share Posted April 20, 2023 I have the manuel and have done the tests ot says needs doing, im waiting on a 2nd hand map sensor coming, the bike keeps cutting out when braking, only fault codes i have is 1 flash and 2 flash but im not getting readings i should off the tests, ive no idea what to do or how, ive recently used injector cleaner in my fuel tank as they was blocked( dont think its related) Link to comment Share on other sites More sharing options...
Member Contributer Bren Posted April 20, 2023 Member Contributer Share Posted April 20, 2023 What codes does the manual say the blinks are? Don't have it with me. Link to comment Share on other sites More sharing options...
toreckman Posted April 20, 2023 Share Posted April 20, 2023 From the manual. For 1 longer flash and 2 shorter flashes Link to comment Share on other sites More sharing options...
toreckman Posted April 20, 2023 Share Posted April 20, 2023 or: If it is 2 codes. Link to comment Share on other sites More sharing options...
toreckman Posted April 20, 2023 Share Posted April 20, 2023 What MAP voltages are you getting? Link to comment Share on other sites More sharing options...
Member Contributer Grum Posted April 20, 2023 Member Contributer Share Posted April 20, 2023 Two short flashes refers to MAP sensor. After checking its vaccum hoses for cracks, breaks and that its electrical connector is properly fitted. If you still get the same fault code you could swap the MAP Sensor for the BARO Sensor, if the fault changes to a code 10 (one long blink) then you have confirmed the original MAP Sensor is faulty. If you still get a code 2 you'll need to check out the MAP Sensor wiring. MAP and BARO Sensors are the same part numbers. Good Luck. Link to comment Share on other sites More sharing options...
