heiwaz Posted May 23, 2021 Posted May 23, 2021 Hello I need to replace the carbs diaphragm of my RC36 4th gen, to install new ones I bought, but I can't remove the old ones. Can you tell me how to do it? Quote
squirrelman Posted May 24, 2021 Posted May 24, 2021 contact the company that sold you the parts for instructions 1 Quote
Member Contributer DannoXYZ Posted May 24, 2021 Member Contributer Posted May 24, 2021 heat up slides in cup of super-hot water (90-C) for 30-seconds. Grab diaphragm with 2 hands on opposite sides. Pull diaphragm apart in opposite directions. Keep on pulling until you see gap develop between diaphragm and slide. Pull upwards on diaphragm on side with gap and peel off diaphragm from slide. Quote
heiwaz Posted May 24, 2021 Author Posted May 24, 2021 2 hours ago, DannoXYZ said: heat up slides in cup of super-hot water (90-C) for 30-seconds. Grab diaphragm with 2 hands on opposite sides. Pull diaphragm apart in opposite directions. Keep on pulling until you see gap develop between diaphragm and slide. Pull upwards on diaphragm on side with gap and peel off diaphragm from slide. I could remove it, but how to insert the new one? I tried and is very difficult. Should I heat it with water too? Quote
Member Contributer DannoXYZ Posted May 24, 2021 Member Contributer Posted May 24, 2021 Yes heat with hot water for 30-sec. Trick to getting on is same in reverse. Grab opposite sides of diaphragm and pull apart. Note that hole becomes slit which is wider than diameter of slide. Slide slit forward over slide so bottom of slit slides into groove. Keep diaphragm pulled apart and saw laterally to drive into groove. At same time, move diaphragm forwards and continue over slide's groove. Once entire diaphragm has been slid over slide, rotate it about 30-60 degrees in each direction to fully seat in groove. If that didn't make sense, I can take some photos or make video. Quote
heiwaz Posted May 24, 2021 Author Posted May 24, 2021 I think understand more less your explain, but I'm not sure I can be insert diaphragm completely in the gap and once inserted can be rotate well to adjust at correct position. Maybe a video or photo will help me a lot. Thanks for your reply Quote
heiwaz Posted May 24, 2021 Author Posted May 24, 2021 12 hours ago, DannoXYZ said: Yes heat with hot water for 30-sec. Trick to getting on is same in reverse. Grab opposite sides of diaphragm and pull apart. Note that hole becomes slit which is wider than diameter of slide. Slide slit forward over slide so bottom of slit slides into groove. Keep diaphragm pulled apart and saw laterally to drive into groove. At same time, move diaphragm forwards and continue over slide's groove. Once entire diaphragm has been slid over slide, rotate it about 30-60 degrees in each direction to fully seat in groove. If that didn't make sense, I can take some photos or make video. I have broken 2 diaphragm trying to insert it 🤦♂️. One of them almost insert it completely. I heath it with water and stretched to get thinner, but if I stretched to much it broke. Quote
squirrelman Posted May 24, 2021 Posted May 24, 2021 jbm (jdm ?) supplies those parts, and i believe they will install them if you require so contact them. 1 Quote
Member Contributer Thumbs Posted May 25, 2021 Member Contributer Posted May 25, 2021 15 hours ago, squirrelman said: jbm (jdm ?) supplies those parts, and i believe they will install them if you require so contact them. Theres NRP who sell them fitted or loose https://nrp-carbs.co.uk/ Quote
heiwaz Posted May 25, 2021 Author Posted May 25, 2021 2 hours ago, Thumbs said: Theres NRP who sell them fitted or loose https://nrp-carbs.co.uk/ They don't sell. In price appear to call them for 4th gen Quote
Member Contributer DannoXYZ Posted May 26, 2021 Member Contributer Posted May 26, 2021 On 5/24/2021 at 12:43 PM, heiwaz said: I have broken 2 diaphragm trying to insert it 🤦♂️. One of them almost insert it completely. I heath it with water and stretched to get thinner, but if I stretched to much it broke. Don't stretch too much. Just enough so length of slit = diameter of slide's groove. Quote
heiwaz Posted May 26, 2021 Author Posted May 26, 2021 7 hours ago, DannoXYZ said: Don't stretch too much. Just enough so length of slit = diameter of slide's groove. If I don't stretch too much is impossible to insert in gap because I need to get thinner stretching them. Quote
Member Contributer Thumbs Posted May 26, 2021 Member Contributer Posted May 26, 2021 20 hours ago, heiwaz said: They don't sell. In price appear to call them for 4th gen What did they say? Quote
squirrelman Posted May 26, 2021 Posted May 26, 2021 maybe send your vacuum slides to danno for diaphragm replacement as he seems quite competent and has the necessary experience. 1 Quote
