Member Contributer Duc2V4 Posted May 5, 2021 Member Contributer Share Posted May 5, 2021 I'm pretty sure I know the answer but will ask anyway in case I'm wrong. If one was to replace the oil pan on a 5 Gen (Due to the fairing stays being part of the oil pan). Does one have to lower or remove the headers? Something tells me there isn't enough room between the oil pan and headers to remove it without moving the headers out of the way. Cheers Link to comment Share on other sites More sharing options...
Member Contributer Cogswell Posted May 6, 2021 Member Contributer Share Posted May 6, 2021 3 hours ago, Duc2V4 said: I'm pretty sure I know the answer but will ask anyway in case I'm wrong. If one was to replace the oil pan on a 5 Gen (Due to the fairing stays being part of the oil pan). Does one have to lower or remove the headers? Something tells me there isn't enough room between the oil pan and headers to remove it without moving the headers out of the way. Cheers Correct - the oil pump intake is near the bottom of the pan. The pan needs to come down just about the height of the pan to clear the pump intake. Link to comment Share on other sites More sharing options...
Member Contributer Duc2V4 Posted May 6, 2021 Author Member Contributer Share Posted May 6, 2021 2 minutes ago, Cogswell said: Correct - the oil pump intake is near the bottom of the pan. The pan needs to come down just about the height of the pan to clear the pump intake. That was my recollection, just needed confirmation. Thanks for the response. Link to comment Share on other sites More sharing options...
