Beobg Posted July 18, 2017 Posted July 18, 2017 Hello everyone I'm new to this forum so if I'm wrong about something, please do not mind. I have little problems with my long-awaited motorcycle.Honda VFR 800 Interceptor, year 2001. During one ride, the car cut me off I hit directly in the open hole of a sewage shaft with the rear wheel, a computer that was not (fixed) tied up broke three cables that I pitched and somehow dragged home with visible problems with gas. Namely, he did not want to receive gas in the range of over 2000 rpm to some 5000 rpm. I called the repairman and replaced some things by the way, but the situation does not improve, it still does not receive the gas properly. I replaced the fuel filter in the reservoir, it was mature to replace it, I turned it into a regular service, I bought another TPS, I carried the computer on diagnostics, cleaned the nozzles, examined the installation, and I still failed to solve the problem. Now I have also ordered a second fuel pressure regulator, because that's how the other bike I had behaved, so we'll see. Does anyone have any recommendation if it's not something else to watch because I can not and will not pay the repairmans who come to see it say something, I buy it and tahts not it. And then im again at the beginning. Did anyone had similar problems and how did he solve them? Please understand me I have not sat on my bike for 3 months I'm suffering with a malfunction. I hope that as two-wheel brothers you can understand me and help if you can. Thank you for your time I wish you safe roads and fill up tanks. Greeting Quote
Member Contributer zupatun Posted July 18, 2017 Member Contributer Posted July 18, 2017 I cannot help. However, please change your title to something like: "FI system malfunction/Fueling problems--HELP!" this way the problem is specific in your subject title...you should get more help that way! Matt Quote
Member Contributer Terry Posted July 18, 2017 Member Contributer Posted July 18, 2017 Does your FI light blink or stay on? Have you tried the diagnostic procedure to read the malfunction does? Quote
