BluRoad Posted March 24, 2017 Share Posted March 24, 2017 1990 VFR750 So I've relocated my coils to under the seat (I did this because the side fairings have been eliminated). I've extended the 12-volt wiring, those check out for correct continuity to the ignition control module, and added longer spark plug wires — new, stranded copper-cored wires with the original OEM caps. The resistance readings from caps to coils meet the checks in the factory service manual. Problem: Both coils are miss-firing as seen with an inductive timing light. What's wrong with this picture? Joe in IL Link to comment Share on other sites More sharing options...
Member Contributer Rice Posted March 24, 2017 Member Contributer Share Posted March 24, 2017 Not sure what is wrong with your setup - Do you have good ground on them? You can actually reuse OEM coils and wires by locating coils on the front and back of the air box. Simple brackets can be made up for that. I'll post a picture of my setup, which I made when thinking about the nekkid look. Link to comment Share on other sites More sharing options...
SEBSPEED Posted March 24, 2017 Share Posted March 24, 2017 Sounds like you have the 12v connections crossed. Pull your plugs out of the motor, connect them to your caps, and turn the motor over while the plugs rest on the motor to see if yo uget spark. If you do, then it's your 12v connections. I use NGK caps when i make new plug wires. Link to comment Share on other sites More sharing options...
mordantly Posted March 31, 2017 Share Posted March 31, 2017 Sebspeed Do you have a source for NGK long caps? Link to comment Share on other sites More sharing options...
SEBSPEED Posted March 31, 2017 Share Posted March 31, 2017 10 hours ago, mordantly said: Sebspeed Do you have a source for NGK long caps? https://www.ngk.com/Motorcycle-Plug-Caps-c543.aspx Use that to find what you need, then google the part number for price shopping purposes.... Link to comment Share on other sites More sharing options...
BluRoad Posted March 31, 2017 Author Share Posted March 31, 2017 That's a pretty innovative install, Rice. As it turns out, the connections were fine, I switched out #2 coil and all appears fine. I was getting bad timing light signals back near the coils, but strong and steady in the middle of the run (?). Thanks. Link to comment Share on other sites More sharing options...
