npracer Posted August 22, 2016 Share Posted August 22, 2016 I was following the procedure in the installation instructions for the removal of the left middle cowl. I removed all the bolts and clips as per the instructions, but the cowl will not come off. Has anyone removed it? What am I missing? Link to comment Share on other sites More sharing options...
Member Contributer NodakVFR Posted August 22, 2016 Member Contributer Share Posted August 22, 2016 You need to push it toward the rear of the bike. There are a couple of hooks that hold it to the middle cowl. Link to comment Share on other sites More sharing options...
fatshoutybloke Posted August 22, 2016 Share Posted August 22, 2016 Nodak I think he's talking about the middle not the lower. You need to remove the lower panels, then all the outside bolts holding the middle panel to the mounting brackets, the plastic 'scrivets' under the belly pan (all 4), the bolt and clip inside the edge of the lower radiator grille, the two bolts inside under the headlamp each side and the clips to the inside panels by the forks. There's a plastic lug inside the pointed section near the nose so it needs to be pushed forward a cm or two but should come off fairly easily. Link to comment Share on other sites More sharing options...
npracer Posted August 22, 2016 Author Share Posted August 22, 2016 Hi Fatshoutybloke: thanks for your response. Yes, it's the middle cowl I'm having trouble with. I've removed the lower cowl, the inner lower and upper cowls, all the bolts and clips. The cowl seems to be attached along the top edge and at the pointed edge. I will try to move it forward as you suggest. Link to comment Share on other sites More sharing options...
Shinigami Posted August 23, 2016 Share Posted August 23, 2016 i didn't find it necessary to remove the mid-cowl for my install, but I did have to be creative when threading the wire past the frame members. Link to comment Share on other sites More sharing options...
Rsparky Posted August 29, 2016 Share Posted August 29, 2016 The middles do take a little finnagling. I found it's most reliable to keep it from bending outward while sliding, with a little downward force near the cockpit area. Link to comment Share on other sites More sharing options...
