yeah Posted May 29, 2016 Share Posted May 29, 2016 Hello All!!! My 94 has done 173,000kms ( I bought it in 2000 in pristine 22,00km condition ) and mechanically is still in good nick. Visually, well.. not. I've bought a Morgan Carbtune Pro. I paid to have the carby's balanced about 8 years ago and decided to learn now... I found my 3 adapter ports and can't find my balance adjustment screws. My Haynes doesn't tell me where they are even in the carby section. Unless it's the " Air cut-off valve cover screw". Any ideas? I presume the Honda Factory Manual has specific info on this and I wonder if anyone could put up the factory page describing where to find those pesky screws? I've tried to download the Factory Manual from other within this forum but keep getting " File Not Found". Thanks for your time guys and girls!!!! yeah! Link to comment Share on other sites More sharing options...
rhubarb Posted May 29, 2016 Share Posted May 29, 2016 They are not on the side of the carbs. They are 'inside' the carb bank. You need a tool like this to reach them... Link to comment Share on other sites More sharing options...
yeah Posted May 29, 2016 Author Share Posted May 29, 2016 Hey thanks Rhubarb!!! I've just degreased that area and I found them!!!!! Thank you very much!! I'm looking forward to adjusting them......yeah! Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted May 29, 2016 Member Contributer Share Posted May 29, 2016 first try and see if you can reach the screws with the engine cold (using the long, 90 degree screwdriver). This way you get the knack, so when you do this with a warm/hot engine, you are less likely to burn your fingers/hand... see the long screwdriver as a long term expense; you won't need it a lot but you can lend your Carbtune+screwdriver to your mates in exchange for a few beers... Link to comment Share on other sites More sharing options...
yeah Posted May 29, 2016 Author Share Posted May 29, 2016 Roger Dutchy. yeah! Link to comment Share on other sites More sharing options...
yeah Posted May 29, 2016 Author Share Posted May 29, 2016 Oh, one more thing; I haven't found the adaptor port for cylinder 4. Any ideas please? Thank you. yeah! Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted May 29, 2016 Member Contributer Share Posted May 29, 2016 There are only three adjustor screws as per the picture above. Or you mean the holes to put the rubber tubes on? Note that when new, you need to place a damper in each rubber tube (as per the manual that comes with the Carbtune) Link to comment Share on other sites More sharing options...
atx Posted May 30, 2016 Share Posted May 30, 2016 I had a blast syncing the carbs on my 96 recently, was a bit tricky to read my DIY manometer but the ride angle screw driver made adjustments a breeze. Make sure you point a box fan or something at the radiator while doing it though, almost overheated my 86 while doing it cause the fan wasn't aimed right... http://www.motionpro.com/product/08-0119 Link to comment Share on other sites More sharing options...
yeah Posted May 30, 2016 Author Share Posted May 30, 2016 Thanks Dutchy... I'm looking for the rubber capped port on number 4 carby. I haven't taken the tank off yet for a last really good look down there, between 1 and 4 carby... Link to comment Share on other sites More sharing options...
yeah Posted May 30, 2016 Author Share Posted May 30, 2016 OOOPS!! I found my 4th port...pretty simple once I move a flap... all 4 are very accessible. Thanks a lot all of you for the enthusiasm!!! Off to get 2metres of fuel hose. I'm going to use my spare ( dented.... ) tank. yeah! Link to comment Share on other sites More sharing options...
atx Posted May 31, 2016 Share Posted May 31, 2016 You can do it with your tank in place no problemo. Make sure you leave the airbox and filter in place too. Link to comment Share on other sites More sharing options...
yeah Posted May 31, 2016 Author Share Posted May 31, 2016 Thanks all!!! The first photo is the before....45 mins later and the second photo. Is it my imagination or does it sound more silky? yeah! Link to comment Share on other sites More sharing options...
Suzuki416 Posted May 31, 2016 Share Posted May 31, 2016 I did the same on my wifes CBR last weekend too.... It amazed me how bad it was before - but its absolutely lovely now... Link to comment Share on other sites More sharing options...
