AWP34 Posted May 17, 2016 Share Posted May 17, 2016 Hi I recenlty purchased the 8 spoke wheel. I am need of bearings and seals. Are these the correct OEM parts for the 90-93 VFR750F wheel. Is there another company or option for the rear wheel? I tried all balls racing but they do not have any kits for this wheel. Thank you for your time. 91258-ml7-003 dust seal 91061-mt4-003 bearing 2500-mn8-000 bearing holder Link to comment Share on other sites More sharing options...
Member Contributer Duc2V4 Posted May 17, 2016 Member Contributer Share Posted May 17, 2016 The bearings and seals would be for your year bike not the wheel. Unless your rear bearing and seals are in need of being replaced, your new wheel should just bolt on your existing hub. Link to comment Share on other sites More sharing options...
Member Contributer JZH Posted May 17, 2016 Member Contributer Share Posted May 17, 2016 Replacing all of those parts is usually not done unless the bike has high mileage (btw, the last one is the entire bearing carrier, and the part number begins with 42500-), but if you really want to do so, then you should also add O-RING, SPROCKET HUB (52X2) 91352-MN8-003. But, as Duc2V4 said, all you need to do is to unbolt your old wheel and bolt your new one on! Ciao, Link to comment Share on other sites More sharing options...
