THRASHED Posted April 25, 2016 Share Posted April 25, 2016 I'm having heat issues. I pulled the radiator and the fluid looked perfect and the radiator looks brand new inside (also consulted my local Rad shop). I bought new cap and thermostat just in case. Thermostat looks a little dirty. I'll do a side-by-side test just for grins. I did a fan test and have some questions. In the shop manual it says to run a jumper. Here is what I did. I put two connectors on the wire ends to ensure good contact. I then touched the ends to the battery +/- and got nothing. The radiator was sitting on my knee at the time (is this sufficient ground)? I also tried with and without the wire connected to the temp sensor. Am I missing something, or is the motor toast? 87 VFR700F2 Thanks. Link to comment Share on other sites More sharing options...
Member Contributer Cogswell Posted April 25, 2016 Member Contributer Share Posted April 25, 2016 On later models one wire to the motor is always hot, the wire through the rad switch just goes to ground. As long as you have both wires connected to the battery correctly it should work. Did you confirm the polarity? Link to comment Share on other sites More sharing options...
THRASHED Posted April 25, 2016 Author Share Posted April 25, 2016 I switched polarity just in case, but it should have just run backward. I think it's time to order a new fan. Link to comment Share on other sites More sharing options...
THRASHED Posted April 25, 2016 Author Share Posted April 25, 2016 Hmmm, anybody have any ideas where I might find a new motor? If found a used unit on eBay and that would work I suppose, but I like to buy new. Thanks, Link to comment Share on other sites More sharing options...
THRASHED Posted April 27, 2016 Author Share Posted April 27, 2016 Sooo, it wasn't the fan after all. I re-tested it last night and it works fine. I did the Ohm check on the temp switch and it shows it is dead. I'll be picking one up today. On another electrical-related question, how do I wire in a parallel manual switch for the fan? I still want the temp switch to work but also want to be able to run the fan manually. Link to comment Share on other sites More sharing options...
Member Contributer BCmcrider Posted April 27, 2016 Member Contributer Share Posted April 27, 2016 7 hours ago, THRASHED said: Sooo, it wasn't the fan after all. I re-tested it last night and it works fine. I did the Ohm check on the temp switch and it shows it is dead. I'll be picking one up today. On another electrical-related question, how do I wire in a parallel manual switch for the fan? I still want the temp switch to work but also want to be able to run the fan manually. Easiest just to run a pair of wires from the toggle switch to the temp switch and connect to the spade with a jumper and to the temp switch metal body nut with a small band clamp. Ghetto I know, but so easy. Link to comment Share on other sites More sharing options...
THRASHED Posted April 29, 2016 Author Share Posted April 29, 2016 Sounds simple enough and makes sense. Thanks. Link to comment Share on other sites More sharing options...
