Member Contributer ggathagan Posted August 3, 2015 Member Contributer Share Posted August 3, 2015 I'm working on a friend's '01 VFR and need to have the injectors cleaned.I don't have the equipment to flow test the injectors, but one of the injectors seems to have problems activating whenI put 12v on it. The click of the valve opening is much less pronounced than the other 3 injectors.All 4 injectors measure 13.8-14.4 ohms.I plan on sending the set to Injector RX for cleaning. If the one injector turns out to be defective, they don't charge, but I'll have to replace it.From '98-'01, Honda uses the same fuel injector part number (06164-PCA-000) for the VFR, the CR-V, and one of their outboard boat motors (BF-130).There are a scad of re-rebuilt injectors for sale on eBay, ranging from $120 for a complete set of 4 injectors to $95 for one.Partzilla wants $150 for a new one.So I'll call upon the Wisdom of the List, as we used to say.Would you consider using rebuilt injectors? On a related note: Would it be safe to soak the nozzle end of the injector in carb cleaner in an attempt to clean it? It's my understanding that it's not wise to submerge the entire injector in solvent. Link to comment Share on other sites More sharing options...
Member Contributer Rush2112 Posted August 3, 2015 Member Contributer Share Posted August 3, 2015 You might want to send the whole set in as cores and get a set of flow matched injectors... for the '98-01 VFR800 FactoryPro will provide a full set of flow matched (within 2%) for $120 with exchange or matched at 1% for $180 with exchange http://www.factorypro.com/ Link to comment Share on other sites More sharing options...
Member Contributer ggathagan Posted August 3, 2015 Author Member Contributer Share Posted August 3, 2015 You might want to send the whole set in as cores and get a set of flow matched injectors... for the '98-01 VFR800 FactoryPro will provide a full set of flow matched (within 2%) for $120 with exchange or matched at 1% for $180 with exchange http://www.factorypro.com/ That's definitely worth the money! Even without the exchange. Thanks for the info. I'll call them tomorrow Link to comment Share on other sites More sharing options...
Member Contributer Rush2112 Posted August 3, 2015 Member Contributer Share Posted August 3, 2015 You might want to send the whole set in as cores and get a set of flow matched injectors... for the '98-01 VFR800 FactoryPro will provide a full set of flow matched (within 2%) for $120 with exchange or matched at 1% for $180 with exchange http://www.factorypro.com/ That's definitely worth the money! Even without the exchange. Thanks for the info. I'll call them tomorrow Full disclosure... I haven't used this service. I just knew that FactoryPro offered it. Marc is a pretty awesome guy and I have faith it will work out well. Let us know how everything goes... Link to comment Share on other sites More sharing options...
Member Contributer ggathagan Posted August 3, 2015 Author Member Contributer Share Posted August 3, 2015 Unfortunately, Factory Pro has no stock of that injector, so he can't provide the flow matched option. All he can do is clean and check mine. So I'm back to the original question of whether or not rebuilt injectors are worth considering. Link to comment Share on other sites More sharing options...
Member Contributer Rush2112 Posted August 4, 2015 Member Contributer Share Posted August 4, 2015 There are others that offer the flow matched injector sets... I looked through my saved pages and can't find it. May take a little research or perhaps help from the VFRD team... Link to comment Share on other sites More sharing options...
Member Contributer SCguy Posted August 4, 2015 Member Contributer Share Posted August 4, 2015 I'm sure that InjectorRX can get it working. They worked wonders on mine! Link to comment Share on other sites More sharing options...
Member Contributer MadScientist Posted August 4, 2015 Member Contributer Share Posted August 4, 2015 I have a similar printout like that from WitchHunter performance. I liked the fact that they actually returned all the parts that were replaced. Also, I would caution you against buying cheap injectors from anywhere, rebuilt or not. I've seen quite a few junk knockoffs and shitty "rebuilt" injectors for cars in the last few years and can't imagine that bikes would be immune to this problem. Stuff that comes out of the package stuck open/shut. Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted August 4, 2015 Member Contributer Share Posted August 4, 2015 rebuilding yours are $17 each at mr injector.. its where i always send my customers. http://www.mrinjector.us/ Link to comment Share on other sites More sharing options...
Member Contributer ggathagan Posted August 29, 2015 Author Member Contributer Share Posted August 29, 2015 I ended up buying a set of rebuilt injector that were flow-matched to 2% from an eBay seller. Injectors are all they sell. The injectors were listed for the CRV, but as mentioned, it's the same part. They're working fine, so I consider it $140 well spent. At some point, I'll send the originals in to one of the vendors discussed to have them cleaned and kept as a backup set. Link to comment Share on other sites More sharing options...
Member Contributer Rush2112 Posted August 30, 2015 Member Contributer Share Posted August 30, 2015 I ended up buying a set of rebuilt injector that were flow-matched to 2% from an eBay seller. Injectors are all they sell. The injectors were listed for the CRV, but as mentioned, it's the same part. They're working fine, so I consider it $140 well spent. At some point, I'll send the originals in to one of the vendors discussed to have them cleaned and kept as a backup set. Glad it worked well... which vendor did you use and did they provide flow documentation? Link to comment Share on other sites More sharing options...
Member Contributer ggathagan Posted August 31, 2015 Author Member Contributer Share Posted August 31, 2015 I ended up buying a set of rebuilt injector that were flow-matched to 2% from an eBay seller. Injectors are all they sell. The injectors were listed for the CRV, but as mentioned, it's the same part. They're working fine, so I consider it $140 well spent. At some point, I'll send the originals in to one of the vendors discussed to have them cleaned and kept as a backup set. Glad it worked well... which vendor did you use and did they provide flow documentation? They're called Motorman fuel injection supply eBay store: http://stores.ebay.com/motormanfuelinjectionsupply/ website: http://www.injectors4u.com/ No I didn't receive documentation. It was just a blurb on the item page: http://www.ebay.com/itm/301501342371?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT Link to comment Share on other sites More sharing options...
