apoc Posted July 11, 2015 Share Posted July 11, 2015 Hi, I've bought the T-Rex sliders kit and plan on installing it this week. The rear rear slider is simple, the frame sliders come with instructions but the front wheel slider... there is a nut in the way, on the right hand side. The dealer says it is the axle so I'm worried about removing it. Any advice please? http://t-rex-racing.com/catalog.php?item=560 Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted July 11, 2015 Member Contributer Share Posted July 11, 2015 Are the parts you received look identical to the pic ? Link to comment Share on other sites More sharing options...
apoc Posted July 12, 2015 Author Share Posted July 12, 2015 Thank you for the quick response. Yes it is exactly as per the picture on their website. More substancial than any other sliders I have had before on other bikes. Link to comment Share on other sites More sharing options...
Member Contributer Jochem Posted July 12, 2015 Member Contributer Share Posted July 12, 2015 From the text my guess is that you have to remove the bolt, not the axle. Put the bar through the axle and then screw it all together. I don't think the original bolts go back in place. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted July 12, 2015 Member Contributer Share Posted July 12, 2015 Got it look at the Sato setup and you will see how it works , replace the factory nut with there nut . Link to comment Share on other sites More sharing options...
Member Contributer auggius Posted July 12, 2015 Member Contributer Share Posted July 12, 2015 It's a bolt not a nut. You can remove the bolt with the wheel on the ground. Leave the axle in place. And then assemble as Jochem says. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted July 13, 2015 Member Contributer Share Posted July 13, 2015 ? Sato's are made like this . Link to comment Share on other sites More sharing options...
