checksix Posted July 10, 2015 Share Posted July 10, 2015 I've been looking for a way to convert my '98 VFR to reverse shift so it would be compatible with my other bike (CBR 600) and spotted this on ebay. From the picture it looked like someone took a standard 5th gen rearset and drilled it to accept a shifter and linkage from another bike. For $45 I figured I'd give it a try and see how well it worked. Installation was pretty easy. With the bike on its centerstand and a block of wood under the rear tire, I popped off the plastic covers on the swingarm ends, unscrewed the nut, and tapped out the pivot bolt using a rubber mallet and two foot length of 5/8" pvc pipe. I was worried the swingarm would move out of alignment when the bolt was removed and cause trouble when reinstalling, hence the pvc pipe, but nothing moved. I slipped on the new rearset, reinstalled the pivot bolt by using it to push the pvc pipe back out, and torqued the nut to spec. The only fiddly bit was getting the shifter linkage adjusted. There's very little clearance between the ends of the shift rod, the fairing (to the left) , the kickstand nut (below), and the footpeg (to the right). I had to bend the shift rod into a slight "bow" shape, but everything seems to fit. So now I can ride both bikes without worrying about shifting the "wrong" way on the "wrong" bike. I'm curious if anyone recognizes what parts were used here, or if this is the handiwork of someone on this forum? I would have paid 2x or 3x the price of the ebay item if someone produced this as a product. Link to comment Share on other sites More sharing options...
Member Contributer Terry Posted July 11, 2015 Member Contributer Share Posted July 11, 2015 Looks similar to the parts on a VTR1000F. I've been tempted to do something similar, not for the reverse shift but just to get some adjustability to the gear shift position. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
checksix Posted July 11, 2015 Author Share Posted July 11, 2015 I think you're right. Thanks for the info. Link to comment Share on other sites More sharing options...
VIFFR Posted July 12, 2015 Share Posted July 12, 2015 I havehave no idea what's going in here with this reverse shifter. Care to explain? :) Link to comment Share on other sites More sharing options...
checksix Posted July 12, 2015 Author Share Posted July 12, 2015 Press down to change to higher gear. Pull up to change to lower gear. It's "backwards" from the normal street bike shift pattern, but common on track bikes. Link to comment Share on other sites More sharing options...
VIFFR Posted July 13, 2015 Share Posted July 13, 2015 Press down to change to higher gear. Pull up to change to lower gear. It's "backwards" from the normal street bike shift pattern, but common on track bikes. Thanks :)That would confuse me so much. Now i understand why the op wanted to change Link to comment Share on other sites More sharing options...
Member Contributer yycviffer Posted July 13, 2015 Member Contributer Share Posted July 13, 2015 Hey Checksix, I saw that on ebay. Im glad someone on the forum picked it up! Having just purchased VTR parts I am pretty confident in saying that those are not VTR parts, at least the lever isn't. Very similar, but the VTR lever is aluminum not steel which I think is what yours looks like it's made of. I did a 6 gen rearset conversion a couple years ago so am working on a similar idea. Can't wait to stomp on the lever! Enjoy the great deal, those are the sweetest! Link to comment Share on other sites More sharing options...
checksix Posted July 13, 2015 Author Share Posted July 13, 2015 Yes, the lever is steel. If you do figure out what parts these are, please post the info. I'd like to have spares. Thanks! Link to comment Share on other sites More sharing options...
