makenzie71 Posted May 16, 2015 Share Posted May 16, 2015 I'm running a '98 engine in my buggy with the factory clocks mounted to my dash. Everything was running beautifully until the other day. I go to fire her up and I got no multipanel. Tach still works and the speeo is trying (I took a nasty fall and somehow the speedo needle ended up on the wrong side of stopped) and I have back lighting. For a long time I had a similar problem but it was a bad ground. I've checked the ground to be sure it's good but I have no panel otherwise. Where do I start? Link to comment Share on other sites More sharing options...
TNRabbit Posted May 16, 2015 Share Posted May 16, 2015 Mine just went out, to...following this thread to see if you find it Link to comment Share on other sites More sharing options...
makenzie71 Posted May 17, 2015 Author Share Posted May 17, 2015 Look at all this help! Link to comment Share on other sites More sharing options...
ShadowJP88 Posted May 20, 2015 Share Posted May 20, 2015 Same for me. I know it is the green circuit troubled with rust.... I've read somewhere else in this forum that someone bypass this circuit by soldering cable. Here's some pics. I'm also looking for that thread ;) Link to comment Share on other sites More sharing options...
ShadowJP88 Posted May 20, 2015 Share Posted May 20, 2015 http://www.vfrdiscussion.com/forum/index.php/topic/61180-dead-lcd/?p=719321&hl=canadianviffer&fromsearch=1#entry719321 Link to comment Share on other sites More sharing options...
