Member Contributer CBVFRbikeboy Posted August 31, 2013 Member Contributer Share Posted August 31, 2013 Hi guys. Just putting my '83 750F back together, and have come across a bit of an anomaly with the rear brake torque arm. I'm not sure if there's supposed to be this space around the caliper mount?? The parts fiche doesn't show any shims fitted? If it's there to allow the caliper to slide, should I grease it? cheers ian Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted September 1, 2013 Member Contributer Share Posted September 1, 2013 simple. get the rear wheel up in the air.. spin the wheel.. does it spin free with little if any drang? GOOD! does the brake work without pushing itself to one side?? good ! if either happen. play with it. hope it good to go! Link to comment Share on other sites More sharing options...
Member Contributer CBVFRbikeboy Posted September 1, 2013 Author Member Contributer Share Posted September 1, 2013 does it spin free with little if any drang? there's no fluid in the system yet. does the brake work without pushing itself to one side?? these calipers are designed to slide on their mounts. Unlike later systems where the caliper is fixed, and the disk moves on it's mounts (floating disk systems) if either happen. play with it. hope it good to go! Yeah, I think I'm satisfied the space is designed into the system. cheers ian Link to comment Share on other sites More sharing options...
thx113 Posted September 1, 2013 Share Posted September 1, 2013 My dodgy memory tells me this is one of the places to grease with the 60% moly Honda grease. Link to comment Share on other sites More sharing options...
Member Contributer Captain 80s Posted September 2, 2013 Member Contributer Share Posted September 2, 2013 I just re-assembled an 84, and mine had a rubber washer on the bolt head side. Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted September 2, 2013 Member Contributer Share Posted September 2, 2013 just about ALL rear brake calipers slide. you are asking about spacing.. the only way to see if its right is to test it. i thought the spacing was right on a 4 wheeler but i had a washer in the wrong spot. and it created too much drag. so test it. Link to comment Share on other sites More sharing options...
