Member Contributer unbalanced Posted August 16, 2013 Member Contributer Share Posted August 16, 2013 Check out this Japan custom work - Not sure why the reworked cooling system, but some very trick mods! Link to comment Share on other sites More sharing options...
Member Contributer CornerCarver Posted August 16, 2013 Member Contributer Share Posted August 16, 2013 Wow...she's a beauty! cooling system looks pretty similar to the other V4 racing rads of the period but I have some questions about the thermostat housing, just because or to remedy a malady? I was there was just a close up high def pic of the exhaust all alone on the bench during assembly... Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted August 16, 2013 Member Contributer Share Posted August 16, 2013 Wow. Somebody put a lot of love into that. Wonder what it sounds like.. Link to comment Share on other sites More sharing options...
Member Contributer Kel Posted August 16, 2013 Member Contributer Share Posted August 16, 2013 Looks pretty damn cool. Love the exhaust and swingarm. Having messed with my upper radiator on and off for the past few front ends, I'm guessing the turning radius is crap. Looks like those forks will be hitting that upper rad and limiting turning radius. No biggie on the track but hell around town. I have some questions about the thermostat housing, just because or to remedy a malady? Maybe it's an electronic water pump? Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted August 16, 2013 Member Contributer Share Posted August 16, 2013 The water pump is usually installed down near where the mechanical pump is, so it's never starved for coolant (or so says I). Though it could be a sort of booster pump to get to the top radiator. Link to comment Share on other sites More sharing options...
Member Contributer CornerCarver Posted August 16, 2013 Member Contributer Share Posted August 16, 2013 Kel it may be an optical illusion but the rad end tanks look like triangles and he may have allowed for the forks to hit the main frame or the triples to hit the stops but quite possibly he does suffer from large turn radius in the parking lot. I thought that might be an electronic water pump but thought it must be mounted low like the stocker as well. ? Link to comment Share on other sites More sharing options...
Member Contributer Kel Posted August 16, 2013 Member Contributer Share Posted August 16, 2013 Kel it may be an optical illusion but the rad end tanks look like triangles and he may have allowed for the forks to hit the main frame or the triples to hit the stops but quite possibly he does suffer from large turn radius in the parking lot. I thought that might be an electronic water pump but thought it must be mounted low like the stocker as well. ? Could very well be. Link to comment Share on other sites More sharing options...
Member Contributer unbalanced Posted August 16, 2013 Author Member Contributer Share Posted August 16, 2013 Yea, the steering radius has to suck... But the exhaust is artwork. Someone has sunk some serious time and money into her! Link to comment Share on other sites More sharing options...
