Member Contributer tomk1960 Posted May 24, 2013 Member Contributer Share Posted May 24, 2013 I'm going to be replacing the fork seals on my '84 and wanted to know if anyone here has completely disassembled the lowers. Specifically, I need to know if it's a big deal to get the smal adjustment knob/mechanism off the left leg. I plan to powder coat the legs and anti-dive unit while I have the front end off, but I'll need to get the legs completely apart to do it properly. The anti-dive system is a bit different than what's on my CB1100F: Also, are there any other components that I should consider replacing while I have the forks apart? Thanks. Link to comment Share on other sites More sharing options...
thx113 Posted May 24, 2013 Share Posted May 24, 2013 The knob has a tiny grub screw underneath and once the knob is off (and the trac body is off) the shaft pushes out the back of the fork. Probably need to replace the upper/outer fork bush in each leg. Link to comment Share on other sites More sharing options...
Member Contributer vfrcapn Posted May 25, 2013 Member Contributer Share Posted May 25, 2013 The knob has a tiny grub screw underneath and once the knob is off (and the trac body is off) the shaft pushes out the back of the fork. Probably need to replace the upper/outer fork bush in each leg. +1 Link to comment Share on other sites More sharing options...
Member Contributer ron_al Posted May 25, 2013 Member Contributer Share Posted May 25, 2013 Also, are there any other components that I should consider replacing while I have the forks apart? Thanks. If that picture really & truly shows original rubber brake lines on a 29 year old bike, then you may want to consider replacing those. Steel braided brake lines are a nice upgrade. Ron Link to comment Share on other sites More sharing options...
Member Contributer tomk1960 Posted May 25, 2013 Author Member Contributer Share Posted May 25, 2013 If that picture really & truly shows original rubber brake lines on a 29 year old bike, then you may want to consider replacing those. Steel braided brake lines are a nice upgrade. Ron Those are original brake lines, Ron and you're right in that they should be replaced. Perhaps that will be an upcoming weekend project. The only thing is that the brakes on that bike are unbelievable. I can lock them up with one finger! Link to comment Share on other sites More sharing options...
