Guest apossibly89 Posted May 5, 2013 Share Posted May 5, 2013 I've checked out the sound clips, and I liked what I heard! Temporarily took my stock pipes off my '02 vfr800, and I'm in love the sound. Until I let off the throttle to decel... lots of popping unfortunately. So if I leave my stock pipes off or decide to gut them, I'm thinking I would need to tune my bike to correct the issue. Am I right? Does anybody have a tune for a stock VFR with a gutted exhaust or no exhaust? I looked in previous topics but couldn't find anything. Thanks for the help! Link to comment Share on other sites More sharing options...
soloii Posted May 6, 2013 Share Posted May 6, 2013 I completely gutted the stock cans on my 2007 - no popping on deceleration. I would think that without any cans on the bike, you would have only the catalytic converter and the short sections of pipe, and that would encourage the popping on deceleration. I could be wrong, but I would think that straight pipes from the cat for a similar length as the stock system would exhibit little or no popping. Link to comment Share on other sites More sharing options...
Guest Posted May 6, 2013 Share Posted May 6, 2013 Idk, sounds reasonable that the pipe length would make a difference. Maybe the oxygen in the catalytic converter is causing the popping from the heat and unburnt fuels Link to comment Share on other sites More sharing options...
Noobtastic14 Posted May 6, 2013 Share Posted May 6, 2013 From what I understand the popping is the bike running lean which can be corrected by a power commander. I gutted mine and hard downshift just to hear it pop and purr. Link to comment Share on other sites More sharing options...
4More Posted May 6, 2013 Share Posted May 6, 2013 Ditto on the gutted stock cans for the 2007. Did mine 20,000 miles ago, been lovin it ever since, great the V4 makes! Did not have to retune, gutting the cans probably added a few hp but also dropped the mpg slightly. Link to comment Share on other sites More sharing options...
AndyB Posted May 6, 2013 Share Posted May 6, 2013 Do you have the pair disconnected? Link to comment Share on other sites More sharing options...
Guest Posted May 6, 2013 Share Posted May 6, 2013 Yes, I did disconnect the pair valve. Right now using no exhaust. Also, I can't find a power commander map for gutted or removed pipes, which is why I was asking for your help :) would I need my bike tuned to get that map? Link to comment Share on other sites More sharing options...
AndyB Posted May 6, 2013 Share Posted May 6, 2013 I think the gutted would be roughly equivalent to an aftermarket set of cans, but I can't confirm that. I don't think anyone has made a map for removing the pipe completely. Link to comment Share on other sites More sharing options...
Guest Posted May 7, 2013 Share Posted May 7, 2013 I've had mine gutted, and no PC or any other kind of fuel adjuster. I have no issues with popping, that I can recall... maybe when I rev match to downshift, but my Katana did the same thing. Link to comment Share on other sites More sharing options...
Guest Posted May 7, 2013 Share Posted May 7, 2013 Looks like that's my goal, gut the pipes and run it! Thanks everyone Link to comment Share on other sites More sharing options...
