Bartho Posted March 5, 2013 Share Posted March 5, 2013 has the clock only 12 hour setting? Link to comment Share on other sites More sharing options...
Dae Posted March 5, 2013 Share Posted March 5, 2013 Yes, it has 12 hour setting. it doesn't have AM OR PM. Link to comment Share on other sites More sharing options...
Bartho Posted March 6, 2013 Author Share Posted March 6, 2013 Thanks I'm used to 24 hour settings. I get used to. Link to comment Share on other sites More sharing options...
Guest Posted March 6, 2013 Share Posted March 6, 2013 Yeah, I'm always a bit annoyed when clocks don't have a 24 hour setting. Not really that big of a deal, but I've had a couple disoriented moments when I wake up at a weird time, and it takes a bit to work out where I am, and what time it is, even while staring straight at a clock. Link to comment Share on other sites More sharing options...
Volfy Posted March 6, 2013 Share Posted March 6, 2013 I can understand 24hr setting for an indoor clock, but one would hope, while operating a motorcycle, the rider would have enough other clues to tell him whether it is AM or PM. I guess also, if you are military and got used to 24hr system... Link to comment Share on other sites More sharing options...
Guest Posted March 7, 2013 Share Posted March 7, 2013 Depending on circumstances, one can wake up quite disoriented. Especially if dawn/dusk end up being approximately the same time AM/PM, I've been known to go warp speed to get kitted up and going. I'd rather be ready to go, and find out I have a lot of time to go back inside and sleep, than the other way around. Link to comment Share on other sites More sharing options...
Guest Posted March 7, 2013 Share Posted March 7, 2013 I have fallen asleep on a bike but many years ago, before clocks on bikes existed :) Link to comment Share on other sites More sharing options...
Guest Posted March 8, 2013 Share Posted March 8, 2013 Only times I've fallen asleep on the bike is when I'm using it as the old "Iron Butt Motel"! Which I'm semi-notorious for... it is the real reason I like center stands. Link to comment Share on other sites More sharing options...
Guest Posted July 6, 2013 Share Posted July 6, 2013 I have been unable to set the clock on my '10 VFR. Holding down both buttons with key on has no effect. I also notice that the clock resets to 0100 after I switch off the ignition and turn it back on again. The a and b trip odometers also rest to Zero after ignition on/off cycle. Can anyone suggest whats wrong and how I can fix it? Many thanks. Link to comment Share on other sites More sharing options...
spud786 Posted July 6, 2013 Share Posted July 6, 2013 has the clock only 12 hour setting? The clock is fine to me, wait till you go over 100,000 miles and the odometer resets to zero, cause it only has 5 digits. Link to comment Share on other sites More sharing options...
crakerjac Posted July 8, 2013 Share Posted July 8, 2013 ^^ Wont do that. I was reading in the manual that the ODO won't roll over to 0.... the ODO will latch at 99,999 miles. Link to comment Share on other sites More sharing options...
