Guest Posted March 3, 2013 Share Posted March 3, 2013 Another option I'm considering is getting a bottle jack, and using a long 2x4 under the header of the garage. Tire should be pretty well warmed up now, though. So I suppose I should go out and give it another shot. My problem is that while I can push the bead away from the outer lip of the wheel, it is still on the first horizontal "shelf" if you will. Link to comment Share on other sites More sharing options...
Member Contributer SinNH Posted March 3, 2013 Member Contributer Share Posted March 3, 2013 Drive over with car. Logsplitter. Yikes ! Why not just thrash away with a sledge hammer, better yet a splitting maul. Bulldozer track ? Link to comment Share on other sites More sharing options...
spud786 Posted March 3, 2013 Share Posted March 3, 2013 No dice with the clamp, nor the 2x4 method. All I've accomplished so far is lifting my car up in the air... Leaving the tire in the sun while I try a new recipe for lunch, pulled carnitas. I suppose I'll bug the neighbor to see if she minds me using her truck. if you doing weird stuff like running a car over, I hope you removed the rotors if a front tire Link to comment Share on other sites More sharing options...
Guest Posted March 3, 2013 Share Posted March 3, 2013 Rotor is toast from something else, but I've still got it up on some wood planks. Broke the first bead with just some tire irons, second one is proving difficult. Link to comment Share on other sites More sharing options...
Guest Posted March 4, 2013 Share Posted March 4, 2013 Update: Spooned my ST3's rear tire off, then back on. I'll see about doing my Honda's in a week or two. Link to comment Share on other sites More sharing options...
Member Contributer V-FORE Posted June 17, 2013 Member Contributer Share Posted June 17, 2013 Since I changed both my tires Saturday morning, I remembered that some people did not think the irwin hand clamps worked... Link to comment Share on other sites More sharing options...
