Guest corpsy Posted July 14, 2012 Share Posted July 14, 2012 86 750 silent at startup,once it heats up tick tick tick ,more noticable at idle,sounds to be top end at rear most cylinder head 1,3 cylinders . have checked valves and are spot on.going to run it again in the morning now that everyting is apart just hoping for more suggestions on what to check.bike has 88000k on so maybe its at the end of its rope anyway any help would be appriciated Link to comment Share on other sites More sharing options...
Monk Posted July 14, 2012 Share Posted July 14, 2012 How's 'bought a valve cleaner like MMO, or whatever you choose ? (Gas additive) Link to comment Share on other sites More sharing options...
Member Contributer dutchinterceptor Posted July 14, 2012 Member Contributer Share Posted July 14, 2012 Leaky exhaust/header gasket?? Link to comment Share on other sites More sharing options...
Guest Posted July 14, 2012 Share Posted July 14, 2012 ok ill check the header thanks, i have never put any additives in the fuel but the mileage that is on i would not be suprised that there might be some carbon in it. should seafoam surfice? if it had hydrulic lifters that is as close as i can describe the sound,like a collapsed lifter in a old chev or something.not to descriminate against chevy or anything Link to comment Share on other sites More sharing options...
Monk Posted July 14, 2012 Share Posted July 14, 2012 I use Seafoam but that's more for cleaning and getting water out.......... MMO is for lubing the upper part of the engine(if put in the gas). http://www.marvelmysteryoil.com/index.php/site/faq/ Link to comment Share on other sites More sharing options...
Member Contributer Terry Posted August 30, 2012 Member Contributer Share Posted August 30, 2012 My VFR700's and 750 both ticked at idle, which was down to the gear drive mechanism on the camshafts, which has split gears that are sprung to take up any slack. At idle there is just enough slack to make a bit of a ticking sound. It does no harm apparently (just adds character). Link to comment Share on other sites More sharing options...
