Guest Sneakers Posted June 26, 2012 Share Posted June 26, 2012 My manual transmission gets notchy or harder to change gears when shifting on hotter days (70-80 degrees F) when I'm in some stop and go traffic. The whole time the cooling fan is running non stop till you speed up to about 45 mph. I tried changing from 10-30 to 10-40 weight oil and same thing. Link to comment Share on other sites More sharing options...
interceptorrider Posted June 26, 2012 Share Posted June 26, 2012 Yup. Just like almost very other bike I've owned. Best shifting bikes I've owned.......my two 5th gen VFR's (Y2K yellow bikes), RC51, and this big VFR. Even the 5th gen's got a little notchy if they were hot and stop-n-goin'. Worst shifting bikes I've owned.........anything with a Kawasaki in the name. No luck with them. I just put Amsoil in the 1200. I like it so far, but, it's fresh too. Fresh oil always helps. I rarely go more than 1500 miles on an oil change. Shifting is the reason. Ride safe. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted June 26, 2012 Member Contributer Share Posted June 26, 2012 Yup. Just like almost very other bike I've owned. Best shifting bikes I've owned.......my two 5th gen VFR's (Y2K yellow bikes), RC51, and this big VFR. Even the 5th gen's got a little notchy if they were hot and stop-n-goin'. Worst shifting bikes I've owned.........anything with a Kawasaki in the name. No luck with them. I just put Amsoil in the 1200. I like it so far, but, it's fresh too. Fresh oil always helps. I rarely go more than 1500 miles on an oil change. Shifting is the reason. Ride safe. +1 on that ..... Link to comment Share on other sites More sharing options...
Member Contributer kaldek Posted June 26, 2012 Member Contributer Share Posted June 26, 2012 +1 for me too. I've had two motors in my 6th-gen and they both get notchy when really hot. The 2002 motor was worse, but it had 130,000KM on it anyway. Link to comment Share on other sites More sharing options...
TiN Posted June 26, 2012 Share Posted June 26, 2012 Had bad shift problems off the oem honda oil. +1 on the fresh oil for better shifting. Plain ol' Mobil 1 seems to keep shifting good for the longest time for me. Go figure. Link to comment Share on other sites More sharing options...
Guest Posted June 26, 2012 Share Posted June 26, 2012 I guess I've never noticed shifting issues when it's hot and it's hot here 90's with 90s humidity from May to October I ride in stop and go beach traffic all the time. I will say when the fan kicks in and blows that hot air on you it get's warm very fast had to set through two lights the other day I now know what it feels like to be in a convection oven. Link to comment Share on other sites More sharing options...
Cam2 Posted June 27, 2012 Share Posted June 27, 2012 I was just thinking to myself on the ride in to work this morning that this bike has the most unforgiving of any transmission on any Honda I've owned over the years so I'm finding the same things. Having just said that, it is still a Honda so its still a pretty damn good transmission! Link to comment Share on other sites More sharing options...
midias Posted August 6, 2012 Share Posted August 6, 2012 I seem to have trouble down shifting at low speeds or going from N to 1st when I get the bike hot and ride a while. Link to comment Share on other sites More sharing options...
Guest Posted August 12, 2012 Share Posted August 12, 2012 If you use synthetic oil instead of Dynasaur oil, it lessens the problem. Keep the weight 10w-40. Don't go thicker or you'll have shifting problems on cold mornings. Link to comment Share on other sites More sharing options...
Member Contributer kebrider Posted August 15, 2012 Member Contributer Share Posted August 15, 2012 I guess I've never noticed shifting issues when it's hot and it's hot here 90's with 90s humidity from May to October I ride in stop and go beach traffic all the time. I will say when the fan kicks in and blows that hot air on you it get's warm very fast had to set through two lights the other day I now know what it feels like to be in a convection oven. The girl and I had a blast strafing the dragon with our Tmax. Miss having it in the garage but the Tiger 800 is fun too. Take the rubber bump-stop on the centerstand and slice it in half with a razor knife. You will instantly have the ground clearance the scoot deserves. Keep the tire pressure up and a Tmax is a damn fine handling machine. Link to comment Share on other sites More sharing options...
Volfy Posted August 17, 2012 Share Posted August 17, 2012 My manual transmission gets notchy or harder to change gears when shifting on hotter days (70-80 degrees F) when I'm in some stop and go traffic. The whole time the cooling fan is running non stop till you speed up to about 45 mph. I tried changing from 10-30 to 10-40 weight oil and same thing. I would kill for 70-80F. Around these parts right now is more like 95F and 80+RH. Heat index is often 105F or higher. The Concours 14 tranny gets very notchy too when warmed up. That's with Mobil 1 10W40 synthetic. I just have to make sure to preload the shift lever, then snick it in with a quick clutch pull. Link to comment Share on other sites More sharing options...
parchedson Posted August 22, 2012 Share Posted August 22, 2012 I seem to have trouble down shifting at low speeds or going from N to 1st when I get the bike hot and ride a while. This is my problem. Doesn't matter on hot or cold days...the damn thing doesn't like neutral to 1st gear. My lack of grace finesse on some stops probably doesn't help much either. Link to comment Share on other sites More sharing options...
