Member Contributer karhawk Posted May 7, 2012 Member Contributer Share Posted May 7, 2012 Anybody done it and tested yet?? my coffin style rear clutch res. is hitting the fairing on right turn after last minute fairing adjustment. Is there a different master with remote reservoir like I have on the front brake side? Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted May 7, 2012 Member Contributer Share Posted May 7, 2012 1) I would definitely have my coils grounded one way or another. At least run a ground wire if you're happy where they are mounted. Going along with that, my coils stopped working when they lost their ground, but maybe some other wiring issue was the cause, if yours is working. Hmmm. 2) Yes, there are other ones you can use. Think an RC51 is an option. I went with a different one, but forgot which one I got. Just have to make sure the intermals are the same dimension. Link to comment Share on other sites More sharing options...
Member Contributer karhawk Posted May 7, 2012 Author Member Contributer Share Posted May 7, 2012 1) I would definitely have my coils grounded one way or another. At least run a ground wire if you're happy where they are mounted. Going along with that, my coils stopped working when they lost their ground, but maybe some other wiring issue was the cause, if yours is working. Hmmm. 2) Yes, there are other ones you can use. Think an RC51 is an option. I went with a different one, but forgot which one I got. Just have to make sure the intermals are the same dimension. Thanks I looked at one on Ebay, it looks like the res. is mounter to the top of the master? I would need something with a remote reservoir to clear fairing http://www.ebay.com/itm/SUZUKI-GSXR-1000-TL1000R-TL1000S-CBR-1000RR-RC51-VTR-RVT-CLUTCH-MASTER-CYLINDER-/150809157451?pt=Motorcycles_Parts_Accessories&hash=item231ced1f4b&vxp=mtr#ht_1535wt_915 Link to comment Share on other sites More sharing options...
douglasthecook Posted May 8, 2012 Share Posted May 8, 2012 I'm at work, so the eBay link doesn't work for me now, but I believe I have the a spare RC-51 clutch master cylinder if you're interested. I have Brembo's now, and just moved the reservoir around until I got the clearance that was required. Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted May 8, 2012 Share Posted May 8, 2012 Ducati, if you can sort out the piston diameters and find one the same? Maybe join a Ducati forum to ask, and piss off the Ducatisti? Link to comment Share on other sites More sharing options...
Member Contributer karhawk Posted May 9, 2012 Author Member Contributer Share Posted May 9, 2012 Ducati, if you can sort out the piston diameters and find one the same? Maybe join a Ducati forum to ask, and piss off the Ducatisti? Still trying to get feedback regarding radial masters, an ebay seller has a universal radial clutch master with a 19mm bore and claims it is compatible with 14mm units. Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted May 10, 2012 Member Contributer Share Posted May 10, 2012 If the box is anything to go off of, I ended up with a 1098 clutch master. But I didn't pay much for it, so we'll see if it works (with the clutch slave). Link to comment Share on other sites More sharing options...
Member Contributer karhawk Posted May 11, 2012 Author Member Contributer Share Posted May 11, 2012 1) I would definitely have my coils grounded one way or another. At least run a ground wire if you're happy where they are mounted. Going along with that, my coils stopped working when they lost their ground, but maybe some other wiring issue was the cause, if yours is working. Hmmm. 2) Yes, there are other ones you can use. Think an RC51 is an option. I went with a different one, but forgot which one I got. Just have to make sure the intermals are the same dimension. Thanks I looked at one on Ebay, it looks like the res. is mounter to the top of the master? I would need something with a remote reservoir to clear fairing http://www.ebay.com/...r#ht_1535wt_915 Thanks I grounded them to be safe. Link to comment Share on other sites More sharing options...
Member Contributer karhawk Posted May 11, 2012 Author Member Contributer Share Posted May 11, 2012 If the box is anything to go off of, I ended up with a 1098 clutch master. But I didn't pay much for it, so we'll see if it works (with the clutch slave). I bought an 08 Kawasaki Z something we will compare notes. Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted May 11, 2012 Member Contributer Share Posted May 11, 2012 I need to buy a clutch slave cylinder first before I can do that... Link to comment Share on other sites More sharing options...
MagnetMan Posted May 11, 2012 Share Posted May 11, 2012 From what I've found out recently the radial brake and clutch levers are mechanically very different: on radials the pivot point for the lever is closer and the lever arm to the master is shorter. That means even if you find a radial master of the same size (14mm clutch on VFR) it likely won't feel right. The throw and pressure might be way off. I'm thinking the way to go might be to find a radial setup that displaces the same volume of fluid as the stock masters. Or, you could just try different setups till one works. That's probably what I'm going to end up doing. Link to comment Share on other sites More sharing options...
Question
karhawk
10 answers to this question
