Guest JeffLaurence Posted February 24, 2012 Share Posted February 24, 2012 Can I turn the bottom mount on a 929 shock 90 degrees without screwing up the internal valving or adjustments? Thanks Jeff Link to comment Share on other sites More sharing options...
V4 Rosso Posted February 25, 2012 Share Posted February 25, 2012 Yes. You can rotate it by any angle. Link to comment Share on other sites More sharing options...
Member Contributer JamieDaugherty Posted March 30, 2012 Member Contributer Share Posted March 30, 2012 Yes. You can rotate it by any angle. +1 Link to comment Share on other sites More sharing options...
Guest Posted March 30, 2012 Share Posted March 30, 2012 How does the bottom adjuster work to vary the damping? Also where would a good place be to start regarding settings? Turns out from closed? Thanks, Jeff Link to comment Share on other sites More sharing options...
Member Contributer JamieDaugherty Posted April 1, 2012 Member Contributer Share Posted April 1, 2012 There is a rod that goes up the center of the piston shaft to the valving piston inside. The end of the rod is tapered to make a needle/seat arrangement. Settings...... on a stock shock I'd start at 2 turns out and adjust from there. Feel free to play around to find something you like. Link to comment Share on other sites More sharing options...
