Guest deltatango Posted April 6, 2011 Share Posted April 6, 2011 Ill take plenty of pics and let the community know how it goes. I know plenty of other people have this setup, but I never saw a complete ground up how to. Hopefully I can make one as the parts arrive....work willing.... the case was a little more expensive than I had seen in older posts. It was 54.39 with a 15% off code, I had to pay shipping though.... The top rack was 160! Seems wierd having a rack that cost three times the cost of the case, especially when Pamela Anderson is not involved.... Link to comment Share on other sites More sharing options...
VFR4Lee Posted April 6, 2011 Share Posted April 6, 2011 Seems wierd having a rack that cost three times the cost of the case, especially when Pamela Anderson is not involved.... The rack is more important than the case regardless if it's Givi or Anderson. Link to comment Share on other sites More sharing options...
timmythecop Posted April 6, 2011 Share Posted April 6, 2011 the age old question: Box or rack? Link to comment Share on other sites More sharing options...
Member Contributer 5thGenJim Posted April 6, 2011 Member Contributer Share Posted April 6, 2011 the age old question: Box or rack? Box, then rack, weed-hoppah! Link to comment Share on other sites More sharing options...
Guest Posted April 11, 2011 Share Posted April 11, 2011 So when the Givi FZ166 arrives this is what you will find. The hardware included is excellent and complete, no parts store runs needed. Very well made, the welds and bends are just beautiful! Looks like it can take much more then the specified 22 lbs max load. To install it on the bike you only have to remove one bolt, which can be seen above the muffler here. The instructions are very good and specify that you install everything loose, and tighten in reverse of install after the monokey top plate is installed. Here are the racks installed loose. You have to remove the bolts that hold down the rear handles and swap them out for longer ones, which are included, to bolt down the two support braces Plate installed and rack tightened. I forgot to take a picture with the JCW case on....I'll do that tomorrow. Link to comment Share on other sites More sharing options...
