Member Contributer AnikMankar Posted December 13, 2010 Member Contributer Share Posted December 13, 2010 So one of my signal connectors is broken. Not the bulb holder but the connector at the wire harness side. The wires are broken off to close to the connector so can't repair it. Any ideas where i can buy one of these. Looks like it comes with the entire wire harness. Thanks Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted December 13, 2010 Member Contributer Share Posted December 13, 2010 Not sure what connector you are looking for, but check out Eastern Beaver. It's in the links section. Link to comment Share on other sites More sharing options...
Member Contributer AnikMankar Posted December 13, 2010 Author Member Contributer Share Posted December 13, 2010 Not sure what connector you are looking for, but check out Eastern Beaver. It's in the links section. thanks found it http://www.easternbeaver.com/Main/Elec__Products/Connectors/Honda_B_T_Connectors/honda_b_t_connectors.html Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted December 13, 2010 Share Posted December 13, 2010 Anik, I have a spare attached to a partially-butchered wiring harness. I could cut off a good length of the wires and the connector and post it to you. Link to comment Share on other sites More sharing options...
ericlw Posted December 13, 2010 Share Posted December 13, 2010 you could push the pins out and recrimp the wires to the pins. Link to comment Share on other sites More sharing options...
Member Contributer AnikMankar Posted December 14, 2010 Author Member Contributer Share Posted December 14, 2010 Anik, I have a spare attached to a partially-butchered wiring harness. I could cut off a good length of the wires and the connector and post it to you. thanks ..I ordered these online. Plus got it working by passing the wires thru. Temporary solution till i get the shipment. Thanks again. Link to comment Share on other sites More sharing options...
Member Contributer AnikMankar Posted December 14, 2010 Author Member Contributer Share Posted December 14, 2010 you could push the pins out and recrimp the wires to the pins. that was the initial thought - but the pins seem to be jammed. I struggled for about 2 hours to take them out Managed to push the wires thru ...it seems to hold and work at this point. VFR - 7433 Bulb Connector.jpg Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted December 14, 2010 Share Posted December 14, 2010 Anik, I have a spare attached to a partially-butchered wiring harness. I could cut off a good length of the wires and the connector and post it to you. thanks ..I ordered these online. Plus got it working by passing the wires thru. Temporary solution till i get the shipment. Thanks again. Ok, glad to hear. Link to comment Share on other sites More sharing options...
