Member Contributer spaceman Posted October 9, 2010 Member Contributer Share Posted October 9, 2010 Just had an F4i resprung and rebuilt and will be installing this week. This shock has a ramped-type adjuster, so am I correct in assuming that #1 is full soft and #7 full hard? Also, how the heck do I adjust this when setting sag? Is there a way to get a spanner type wrench in there once I get the wheel back on? Once preload is set for me, that's it as I don't ride with passengers or heavy luggage. Thanks. Link to comment Share on other sites More sharing options...
Member Contributer jaimev34 Posted October 9, 2010 Member Contributer Share Posted October 9, 2010 You should be able to get a spanner in there. If you don't have one, maybe you could use something else the twist it. Link to comment Share on other sites More sharing options...
Member Contributer spaceman Posted October 9, 2010 Author Member Contributer Share Posted October 9, 2010 Anyone know where I can get a spanner for this shock? Link to comment Share on other sites More sharing options...
Baileyrock Posted October 9, 2010 Share Posted October 9, 2010 turtlecreek was one of the first to do this mod(FotoMoto was first) and said it's a PIA to adjust but doable and once correct SAG is set forgetaboutit! :fing02: PS I'll mod your title to say shock as I and others have F4i forks too! :blush: BR Link to comment Share on other sites More sharing options...
Member Contributer spaceman Posted October 9, 2010 Author Member Contributer Share Posted October 9, 2010 turtlecreek was one of the first to do this mod(FotoMoto was first) and said it's a PIA to adjust but doable and once correct SAG is set forgetaboutit! :fing02: PS I'll mod your title to say shock as I and others have F4i forks too! :blush: BR Thanks. Well, I got the shock in today, and as soon as I have a few set of extra hands, I'll set sag. Looking at this thing once installed, I don't know how the hell one could even get a spanner-type adjustment wrench in there. I'll most likely go the "long, heavy screwdriver" route and gently tap her where it needs to go. Link to comment Share on other sites More sharing options...
Baileyrock Posted October 10, 2010 Share Posted October 10, 2010 turtlecreek was one of the first to do this mod(FotoMoto was first) and said it's a PIA to adjust but doable and once correct SAG is set forgetaboutit! :fing02: PS I'll mod your title to say shock as I and others have F4i forks too! :blush: BR Thanks. Well, I got the shock in today, and as soon as I have a few set of extra hands, I'll set sag. Looking at this thing once installed, I don't know how the hell one could even get a spanner-type adjustment wrench in there. I'll most likely go the "long, heavy screwdriver" route and gently tap her where it needs to go. If you got the right spring then just set it on the 3rd rung and call it good, check Sag of course! :biggrin: Link to comment Share on other sites More sharing options...
Member Contributer spaceman Posted October 10, 2010 Author Member Contributer Share Posted October 10, 2010 turtlecreek was one of the first to do this mod(FotoMoto was first) and said it's a PIA to adjust but doable and once correct SAG is set forgetaboutit! :fing02: PS I'll mod your title to say shock as I and others have F4i forks too! :blush: BR Thanks. Well, I got the shock in today, and as soon as I have a few set of extra hands, I'll set sag. Looking at this thing once installed, I don't know how the hell one could even get a spanner-type adjustment wrench in there. I'll most likely go the "long, heavy screwdriver" route and gently tap her where it needs to go. If you got the right spring then just set it on the 3rd rung and call it good, check Sag of course! :biggrin: :fing02: Sounds good to me! Yes, it has the right spring courtesy of Jamie Daugherty. Thanks for your help. Link to comment Share on other sites More sharing options...
Monk Posted June 18, 2011 Share Posted June 18, 2011 Jamie Daugherty is making/moding a rear shock for me as we speak. I don't have abs and do have a wheel hugger.... I looked at the service manual and it looks like a simple swap-out... Can it be done without removing hugger ?..........I'm also thinking if I pre-set the pre-load 1 click harder than what I think it should be, that it would make it easier to move after installed if the sag is off?...........Also is there anything I need to know about, to do the swap myself ? As BR said about a month or so ago, "it's best to do both ends at the same time" ........... Well, I did the front 1st, without doing the rear($$$, & still thinking which avenue to go on the rear. New, or rebuild). So the results of just doing the front was very positive, but as my bike felt more planted, the corning speed increased which finally brought me to what BR was saying, "Do both ends"........ Because now I can see where the front is wanting to go, and the rear is saying take it easy. BR was right, it just took my slow-self, to get to that point. Link to comment Share on other sites More sharing options...
Member Contributer spaceman Posted June 19, 2011 Author Member Contributer Share Posted June 19, 2011 I just put it on the center stand, took off the rear wheel, and went to work. The stock shock came out easy, the f4i took a little "wiggling" but not too bad (this was my first time doing this btw). I haven't done the front yet. I'm still waiting to get my new workshop built. I'm still on the fence on whether I'll attempt it, or have someone do it for me. One word of advice.....set that preload adjuster before you install it! Its a big PIA to set once in. I wish there was an easier way! Link to comment Share on other sites More sharing options...
Monk Posted June 19, 2011 Share Posted June 19, 2011 I just put it on the center stand, took off the rear wheel, and went to work. The stock shock came out easy, the f4i took a little "wiggling" but not too bad (this was my first time doing this btw). I haven't done the front yet. I'm still waiting to get my new workshop built. I'm still on the fence on whether I'll attempt it, or have someone do it for me. One word of advice.....set that preload adjuster before you install it! Its a big PIA to set once in. I wish there was an easier way! Do you have to remove the exhaust or anything like that ? Link to comment Share on other sites More sharing options...
Member Contributer Knute Posted June 19, 2011 Member Contributer Share Posted June 19, 2011 I just put it on the center stand, took off the rear wheel, and went to work. The stock shock came out easy, the f4i took a little "wiggling" but not too bad (this was my first time doing this btw). I haven't done the front yet. I'm still waiting to get my new workshop built. I'm still on the fence on whether I'll attempt it, or have someone do it for me. One word of advice.....set that preload adjuster before you install it! Its a big PIA to set once in. I wish there was an easier way! Do you have to remove the exhaust or anything like that ? I put this shock in my '04. For me at first it was a struggle, I ended up taking off nearly everything, exhaust, rear cowl, that plastic fender thing... I just couldn't wiggle the darn thing into position otherwise. But once I had a good clear work space I was able to get the torque wrench into action on all the bolts. I took BR's advice and just set the preload at #3, haven't figured out a method for getting a wrench in for adjusting it yet. Had Jamie do the rebuild on the shock and install RT gold valves the front end at the same time. Very pleased. Link to comment Share on other sites More sharing options...
Member Contributer SereniTTy Posted June 19, 2011 Member Contributer Share Posted June 19, 2011 I just put it on the center stand, took off the rear wheel, and went to work. The stock shock came out easy, the f4i took a little "wiggling" but not too bad (this was my first time doing this btw). I haven't done the front yet. I'm still waiting to get my new workshop built. I'm still on the fence on whether I'll attempt it, or have someone do it for me. One word of advice.....set that preload adjuster before you install it! Its a big PIA to set once in. I wish there was an easier way! Do you have to remove the exhaust or anything like that ? I did not have to remove the exhaust. Getting the stock shock out was MUCH more difficult than getting the F4i in. The trick (as I remember) with the F4i was figuring out how to feed the remote reservoir though first as I twisted the shock into place. I left my shock set at full soft, and with my JD set spring, my sag was pretty much perfect. I agree that it would be easier to start a 3 and back off if needed than to try to go up later if needed. Don't forget your stack of washers to set your ride height.... Link to comment Share on other sites More sharing options...
Monk Posted June 19, 2011 Share Posted June 19, 2011 Thx for the responces, looks like I'll at least have to take my wheel-hugger off. I'm not sure if I'll be having that adjustment problem, it looks like it's at the top of this shock(CBR929 shock)? Link to comment Share on other sites More sharing options...
Member Contributer spaceman Posted June 19, 2011 Author Member Contributer Share Posted June 19, 2011 I did not remove the exhaust, but more space would have been nice. Link to comment Share on other sites More sharing options...
Member Contributer Knute Posted June 20, 2011 Member Contributer Share Posted June 20, 2011 I just put it on the center stand, took off the rear wheel, and went to work. The stock shock came out easy, the f4i took a little "wiggling" but not too bad (this was my first time doing this btw). I haven't done the front yet. I'm still waiting to get my new workshop built. I'm still on the fence on whether I'll attempt it, or have someone do it for me. One word of advice.....set that preload adjuster before you install it! Its a big PIA to set once in. I wish there was an easier way! Do you have to remove the exhaust or anything like that ? I put this shock in my '04. For me at first it was a struggle, I ended up taking off nearly everything, exhaust, rear cowl, that plastic fender thing... I just couldn't wiggle the darn thing into position otherwise. But once I had a good clear work space I was able to get the torque wrench into action on all the bolts. I took BR's advice and just set the preload at #3, haven't figured out a method for getting a wrench in for adjusting it yet. Had Jamie do the rebuild on the shock and install RT gold valves the front end at the same time. Very pleased. For the sake of clarity, I removed the mufflers, not the exhaust pipes. Link to comment Share on other sites More sharing options...
Monk Posted June 20, 2011 Share Posted June 20, 2011 Is there a how to for changing the rear shock with minimal parts being removed? Link to comment Share on other sites More sharing options...
Monk Posted June 20, 2011 Share Posted June 20, 2011 I found this in the suspenion section after going though "8" pages, for those of you that will be wanting to know this in the future. Link to comment Share on other sites More sharing options...
